| General Material Machining Solutions Discuss Material Machining Problems and Solutions Here. |
Greetings, I am trying to cut a 8 inch PVC couple to different lengths to use as a case for a permanent magnet alternator. I am now using a table saw to make the cuts, but the results are not very professional looking. If anyone can recommend a better technique, jig, or method that will produce a better looking result please let me know. |
Greetings, I found a solution for cutting large diameter pipe. I can adjust it for 6 to greater than 8 inch. It will cut PVC and metal. The grinder is fed into the pipe using the small turn buckle. Then the unit is rolled around the pipe to make the cut. |
Hi, I completed rebuild of large diameter plastic pipe cutter. The configuration is modeled after a design seen on the web, just like the earlier version. The cutter is stationary and the pipe spins. The stationary cutter configuration allows for a AC powered cut off tool to be used. I am able to mount the pipe and then slide the cutter to the measured cut off position. The new configuration will also help eliminate waste as long as I measure twice and cut once. Enjoy the day. |
You are the Man! very clever idea! |
| Requesting help with DeskCNC ??? | Burnit0017 | Carken Products (Deskam, DeskCNC etc) | 4 | 06-22-2011 05:48 PM |
| Requesting Programs from Machines | stang623 | General CNC (Mill and Lathe) Control Software (NC) | 0 | 10-19-2010 02:48 PM |
| Newbie- Requesting suggestions for aluminum cutting | h4x354x0r | General Metal Working Machines | 6 | 08-02-2010 10:54 AM |
| New guys requesting quick info | Siren | JGRO Router Table Design | 7 | 02-17-2007 08:34 AM |
| Newbie Requesting Help.. Photos Attached | cflanagan | CNCzone Club House | 0 | 01-20-2007 06:43 PM |
