Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 12-30-2010, 06:34 PM
bgator220 is on a distinguished road
Need Help Finishing Aluminum
Hello All,
I am new to the forum. I am working on a cnc mill and milling a bunch of pieces out of small 1/8" aluminum sheet. These pieces have no hold down holes in them but I have made a set of clamps to hold them down well.
My problem is getting a good finish on them. I would really like to have a almost mirror polished finished on them without doing any polishing after they are on the mill. For the finishing, I am using a 4 flute 1/4" endmill, running at about 2900 rpm. I am using a g42 tool diameter offset, cut it out with a 1/4" at .29 diameter, .26 diameter, then put in the finishing bit and use a .25 diameter. So for the finishing pass I am taking off 5 thousandths. Does anyone know how I could get a better finish on them with the mill? Different tooling or speeds?
Im also looking to get some brushed aluminum sheets. I usually order from mcmastercar. Can anyone point me to a place to get better and cheaper sheets. I am getting a lot that are scratched up.
Thanks,
Brian
Old 12-30-2010, 07:19 PM
What is a YT15? And why such the low spindle? what should my feedrate be with that setup?
Finishing/anodizing aluminum 98vert Metal Finishing and Plating 24 02-04-2011 09:28 PM
Finishing aluminum for cookware? sansbury Mass finishing equipment/media/stratigies 3 12-05-2008 11:09 AM
6-flute endmill for finishing aluminum? cnczoner General Metalwork Discussion 3 04-16-2008 11:20 PM
Finishing jrobson Surfcam 16 03-06-2008 03:59 AM
Brush finishing aluminum tubing in quantity mxtras Mass finishing equipment/media/stratigies 17 01-02-2008 10:37 PM
