Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 12-23-2010, 12:39 PM
laminar-flow is on a distinguished road
Aluminum blanks cut to size, where in the PNW?
In an effort to reduce the time spent rough cutting sheet material and pipe / tube to size for machining, I would like to find a source to supply rough, ~ +.100" over, material closest to Seattle, OK, let's make that the west coast.
Parts are usually under 12" square and pipe / tube are usually under 6" diameter.
Quantities are from 5 to 200 pieces at a time.
Any recommendations?
What Size Aluminum To Use In Frame? thomasholley DIY-CNC Router Table Machines 2 08-18-2011 02:25 PM
CNC Fixed Size Mother of Pearl Inlay Blanks jemmyell Product Announcements & Manufacturer News 2 10-27-2009 04:46 PM
mid-size mill for aluminum for $2k? stevet47 Benchtop Machines 48 02-18-2009 02:56 PM
what size aluminum should I use. Regnar DIY-CNC Router Table Machines 0 09-21-2007 03:27 PM
Purchased aluminum, sent wrong size, too big, now what? pzzamakr1980 General Metalwork Discussion 2 09-20-2007 09:54 AM
