Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 12-01-2010, 03:32 PM
gtoutounji is on a distinguished road
Best non metal material for fine details
Hello,
I have a Roland MDX-40A milling machine that I use for carving my models, usually from wood. I have started making molds from the cut pieces and I would like to know what is the best material to cut in order to have the best finish and accurate reproduction of details. My models are small and have fine details. The finished wood piece tend to have sometimes rough finish due to the wood fibers, type of bit, etc.
Thank you,
Ghazi Toutounji
Mississauga, Ontario, Canada
E-mail: ggtoutounji@rogers.com
website: Customized
Business E-mail: info@murexdesigns.com
Old 12-01-2010, 04:04 PM
jalessi's Avatar
jalessi is on a distinguished road
Post
Ghazi,
For awesome detail and easy machinability take a look at machinable wax.
Machinable Wax
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 12-01-2010, 04:45 PM
Hi Jeff,
Thanks for the reply. Is there any cheaper material that gives the same results?
Old 01-08-2011, 01:12 PM
trevj1 is on a distinguished road
Make your own machinable wax, if you need cheap. There are lots of recipes around. Google "Make Machinable wax".
Unless you are scrounging off-cuts and drops from somewhere, you won't find much cheaper.
Cheers
Trev
Old 01-08-2011, 01:57 PM
Thanks Trev,
I already googled some and will search more.
Need Help!- Minnesota Metal Suppliers? Swiss Bar-Fed Material pneumadyne General Metalwork Discussion 0 04-05-2010 04:23 PM
Just IN- Material for projects. Metal and Aluminum geoline4 Product Announcements & Manufacturer News 0 01-31-2009 08:00 AM
Looking for the the material number details lly1001 Bending, Forging,Extrusion... 1 06-28-2008 03:26 AM
What Bit for fine details? teamtexas DIY-CNC Router Table Machines 0 05-11-2008 09:15 PM
Cutting G10 material without metal tools? (CNC milling) burnthills General Metalwork Discussion 5 11-01-2006 01:34 PM
