| General Material Machining Solutions Discuss Material Machining Problems and Solutions Here. |
Hi people. Does anyone knows if the deflection for two steel plates of the same material with the same dimensions but at different hardenings will be the same or not? FX. if a plate is 250mmx1000mmx50mm @ 62 HRC and is loaded in the middle of the plate with a force of 30 metric tonne, will the difference in the deflection then be smaller, than if the plate was hardened to 55 HRC? Thanks in advance |
| The elastic deflection under the same conditions will not change. This depends on a property of the material called Young's Modulus abbreviate E in deflection calculations What will change between non-hard and hardened material is the elastic limit. This will be higher in the case of hardened material. In other words you can apply a greater load to the hardened material, it will deflect further due to the increased load but it will spring back to the original shape. With the non-hard material the same load will deform the material permanently because the lower elastic limit has been exceeded.
| Deflection | nofx | Mechanical Calculations/Engineering Design | 2 | 02-23-2010 07:16 PM |
| How much deflection is too much? | Dman65 | Mechanical Calculations/Engineering Design | 4 | 08-12-2009 08:58 PM |
| Need Help!- Deflection Calculation | Freff | DIY-CNC Router Table Machines | 13 | 11-05-2008 07:40 PM |
| Shaft deflection | CNCTerry | Linear and Rotary Motion | 7 | 06-30-2007 09:49 PM |
| shaft supports and deflection | dwwright | Linear and Rotary Motion | 4 | 01-10-2006 02:06 AM |
