| General Material Machining Solutions Discuss Material Machining Problems and Solutions Here. |
I am new to machining. I've done some drilling but not much. I would like to drill a hole through the axis of an aluminum bolt. The bolt is about 5/16" in diameter and 1" long. The hole will be 1/8". Is it feasible to do this with just a hand drill? I can secure the bolt on a work bench. Thanks! |
| do you have a drill press ? if so clamp a block of metal on the table with a tap drill of the size thread on your bolt drill a hole then tape the hole (don't move the block) then thread the bolt in the hole and drill away put some never sieze on the thread if you use an aluminum block |
| give it a try good luck Kevin |
| Need Help!- deep, small hole drilling in aluminum | Fala_Man | General Material Machining Solutions | 5 | 06-18-2009 04:38 PM |
| bolt parttern around hole | Runner4404spd | Solidworks | 2 | 02-01-2008 06:08 PM |
| bolt hole circle | sanddrag | Employment Opportunity | 5 | 01-23-2007 06:52 AM |
| Drilling a hole in the center of a bolt / newby question | stickben | Mechanical Calculations/Engineering Design | 1 | 04-30-2006 11:07 AM |
| Drilling Bolt Hole Patterns | TURNER | G-Code Programing | 17 | 01-02-2006 06:49 PM |
