10-23-2010, 05:07 PM
Delrin vs. Lexan vs Fiberglass | | Hi, I need some help/input on this.. I'm uncertain which material would be best for this purpose. This setup is a little unique. Basically I'm trying to produce a non-conductive solution for mounting a 22lb antenna 6' feet off the side a tower. I've chosen to use a 1.5" solid round rod for this horizontal arm, but I'm not sure which would be best. I believe fiberglass is the strongest, but I'm worried about it cracking from drilling it and placing harder aluminun tubing over it.
This material will be outside in a windy environment and needs to be tough and survive the element. The rod will stick out 4-5 feet, then a heavy duty piece of aluminum tubing with a 1.54" I.D. will mate with it and provide the last 1-2 feet. I would also like to be able to drill holes through the material to install bolts/mounting hardware. I believe lexan is the strongest and UV doesn't weaken it like Delrin, but I also heard it scratches easily, which then weakens it quickly. Perhaps I could mate the aluminum in a way to prevent it from scratching Lexan, I'm not sure.. I would like for this to be built to last 5 years. |
