Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 10-07-2010, 12:32 PM
gumush is on a distinguished road
CNC machining help.
I have an DIY CNC with 850w kress.
I have 6mm and 3.175mm collet.
I want to use delrin , polyethylen , kestamid , plexi , balsa , polywood 2mm to 12mm
I use 2.5mm 2 flute and one 4mm 2 flute mills.
Makina Takm Endstrisi A.. kesici takmda kalite, cutting tools producer in Turkey
But i didn't decide kress speed , mm/min and how stepdown mm process in one time ?
I use mach3.
Is one mill type suitable for all ? or which mills i have to used ?
And i have a problem with borders.
Thanx for all help.
Old 10-08-2010, 06:59 PM
miniz98 is on a distinguished road
i think that all cnc machines are the same. Some are fast, slow, rigid. Your main problem may be the tooling your using. With delrin you want to use a single fluted emill.Online Machine Shop | Anco Precision Inc. | Instant Quotes
Custom Machining, OEM Machining. peovo-com CNCzone Site News and Contests 0 09-02-2010 04:22 AM
CNC Machining lasershowssrl General Metal Working Machines 0 06-26-2010 06:09 AM
Need Help!- CNC machining juliamart Want To Buy...Need help! 5 04-08-2009 08:42 AM
MIS CNC Machining and tooling - General machining - Thermoform Molds modernprecision Employment Opportunity 0 11-23-2007 10:05 PM
Machining anodized parts or anodize after machining? SRT Mike General Metalwork Discussion 4 03-11-2006 11:22 PM
