| General Material Machining Solutions Discuss Material Machining Problems and Solutions Here. |
| I have a Porter Cable 890 router on my 3 axis K2 machine. The slowest setting is 10,000 rpm, and I am using Precise Bits drill bits designed for cnc with their collet. I am trying to drill 0.25 holes in HDPE, about 3/4 inch deep. I get build up of material on the bit, and by the third hole or so, it has a negative impact on the drilling. I am of the idea I need to slow the bit down? Or, I am thinking of peck drilling so the material cleans out. I am using the drill cycle, can't recall the #... but it is standard. I could use some advice.. |
| I use G83 with 1/4" upcut spirals to peck "drill" in wood. Should work with the drill bits. And I use the same router.
| drilling small holes... with router??? | eloid | DIY-CNC Router Table Machines | 8 | 08-21-2009 01:30 PM |
| Need Help!- Porter Cable router and drilling | THend | CNC Machining Centers | 2 | 03-10-2009 08:16 PM |
| Drilling 0.3mm hole in 2mm Delrin with a router | ssozonoff | General Metalwork Discussion | 0 | 02-03-2009 10:00 AM |
| Need Help!- Drilling holes using trim router? | jeffmorris | General Metalwork Discussion | 0 | 03-25-2008 05:38 AM |
