Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 07-16-2010, 10:03 PM
rigo430's Avatar
rigo430 is on a distinguished road
PVC chip load?
I've got some pieces i need to make out of PVC and i was wondering what kinds of speeds and chip loads people like to use to get good finishes.
Old 07-16-2010, 11:14 PM
stevespo is on a distinguished road
Without knowing what type of machine you're using, or the type of tooling you have available - here's some generic advice for plastics.
Look at what the tool manufacturer recommends for chipload. Some companies publish charts, so use it if you have it.
Without a handy chart, I tend to use 2% chipload, and then I plug the values into feedrate calculator. You may need to adjust it faster or slower, depending on the variables - this is a good middle of the road.
I'm using a high speed spindle on a wood router. I slow down the RPM (12K) and increase the feed rate (IPM) to avoid overheating and welding the plastic. A mist system, or compressed air will also help.
I tend to use a single flute cutter. It gives the chip room to eject and helps with cooling. The "O" type cutters, in a straight flute or spiral work nicely in most plastics. The Onsrud 63-750 series is a great choice for soft plastics.
So, with a 63-775 (.250" diameter) tool at a .008" chipload, and 12K RPM, I'd probably start around 80-90 IPM. Faster RPM will probably require faster IPM. Naturally it depends on what your machine is capable of. You might be able to go quite a bit faster, or slower if your machine is not rigid or smooth enough.
This is just my experience. YMMV.
Steve
Old 07-17-2010, 01:49 PM
rigo430's Avatar
I plan on using either a HAAS VF8 or VF2 super spindle. As far as tooling goes I've got tools meant for aluminum or some router bits i could probably use.
Old 07-17-2010, 02:05 PM
Lucky you. You're not going to have any issues with vibration or precision, and you've got a high speed spindle as well (what do those support 8-10K RPM max?).
The finish (and feedrates) will be better with a dedicated tool because the geometry is designed for the material.
Give it a shot with the router bits, or a 2 flute end mill - it will certainly work. If you're not happy, try one of the Onsrud cutters.
Steve
Chip load/feed per tooth calculation TravisR100 Haas Mills 10 07-21-2010 01:32 PM
Chip load & speed /feed info ynnek DIY-CNC Router Table Machines 0 03-09-2009 08:44 PM
Chip load and cutting depth. SCCoupe DIY-CNC Router Table Machines 3 07-19-2006 02:24 PM
chip load question cncsdr General Metal Working Machines 1 10-11-2004 08:08 AM
