| General Material Machining Solutions Discuss Material Machining Problems and Solutions Here. |
| hello everyone, i am making jewelry prototipe for rubber vulcanised mould to inject wax.. i am looking for a soft metal,machinable,that leaves good detail using carbide V-bit(angle 15°,tip-0.1mm) that can withstand temperature of 190° celsius and some pressure from process of vulcanisation of rubber. even Acrylic would be good if was not melting on about 160°celsius..... what metal can be milled with cheap hong kong V-bits i mentioned and at what speed and feed rate? Thank You |
It's soft and easily machinable, and it should be able to take vulcanizing temperatures (the melting point is 232 C, 450F). It's been used traditionally in the jewelry trade for hand-carving models that are later vulcanized. Use a little oil when cutting it, so it doesn't stick to the cutters. Feedrates and rpms really depend on the size and type of cutters you're using - I'd start slow and try going faster if everything's working okay. Andrew Werby www.computersculpture.com Last edited by awerby; 07-05-2010 at 03:57 PM. Reason: forgot sig line |
| Finally, Soft Jaws that Make Sense | Team Pierson | Product Announcements & Manufacturer News | 0 | 04-28-2008 08:24 PM |
| Newbie. Need to make soft chuck jaws for Mori lathe | bob1112 | General Metal Working Machines | 10 | 03-13-2008 08:07 PM |
| CNC to make Metal Business Cards? | JoeZam | General Metal Working Machines | 10 | 07-11-2007 08:56 AM |
| cnc machined prototypes | cncmedcom | Parts for Radio Control Models | 0 | 05-20-2007 09:39 PM |
| pcb prototypes | xlukkajr | General Electronics Discussion | 1 | 02-18-2007 10:46 PM |
