Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 06-14-2010, 10:25 AM
sanjay0484 is on a distinguished road
finish prpblem
I.D.finish problem in EN19A'T' BS970 material
Old 06-14-2010, 11:03 AM
kling8 is on a distinguished road
You may want to offer more information to your problem, What tool speeds feeds? What finish are you trying to get? What finish do you have now? I would add alot more information if your looking to get some help...
Old 06-15-2010, 01:14 PM
i am using solid carbide reamer dia.8.71mm (6 edges) with 100 r.p.m. n feed 20mm/min. required finish is 0.4 . tool marks are my major problem. the component is cylinder of pistol having 6 chamber holes which are taper in shape. plz help me....thanks
Zinc-Plated Finish vs plain finish for threaded rod? Almaz DIY-CNC Router Table Machines 2 10-21-2008 02:39 PM
Finish on M2 yoopertool Mass finishing equipment/media/stratigies 2 03-26-2008 06:43 AM
How to get this finish dneisler General Metal Working Machines 3 10-11-2007 07:09 PM
Finish Cut How too ??? Biggermens BobCad-Cam 6 04-30-2007 07:59 PM
Bad finish fadalman Fadal 5 12-09-2006 01:00 PM
