Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 06-03-2010, 11:42 AM
Khalid's Avatar
Khalid is on a distinguished road
Collet Runout- What can be repurcussion?
If one has runout in the Quill Collet of Milling machine... Beside, preciosion what can be the repurcussion??.. I have 0.15mm runout at the tool tip, i just need to know beside inacuracies what are other bad effects?
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
Old 06-03-2010, 12:07 PM
HuFlungDung's Avatar
Moderator
Angry boss, indignant customers, loss of reputation, loss of job
Old 06-03-2010, 01:06 PM
Khalid's Avatar
My boss will never angry because i am the boss and i have ZERO customers and no repu.....What i will loose is my hair...i will soon be bald if i never get the right answers..
Old 06-03-2010, 01:12 PM
But if you are bald then you will not be hot headed and angry.
Apart from loss of accuracy when a cut is running out the cutting edges are not cutting evenly. For instance if your feed is 0.01mm per tooth and the runout is 0.1mm obviously only one side of the cutter is making contact with the work and if the cutter has four flutes this side is taking a cut which is 0.04mm so the cutter may break.
Old 06-03-2010, 01:44 PM
Khalid's Avatar
Geof, agreed .. I hate front hair falling, it seems an Airport runway on the head..
Collet runout may be the main culprut of my new endmill breakage.. I will post some more results tomorrow.. I will pocket out some Circle and will see the impact of collet runout on the pocket dimensions...
I have backlash enabled in Mach3, i will also check if the pockets are circular or not..
Thanks for answering
What is Runout ToyMaker FAQ of CNC Machine building 7 01-08-2012 08:15 AM
runout on er20 collet holder? Teyber12 Novakon Systems 3 04-09-2010 07:58 PM
1/8 Collet runout - or ruter runout slavkok Wood Working Tooling 1 03-04-2010 07:24 AM
The collet-held collet holder justgary Tormach PCNC 14 05-27-2009 11:20 AM
Expected runout from an ER32 collet chuck buckie555 General Metal Working Machines 10 04-01-2006 07:32 AM
