Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > General Material Machining Solutions
General Material Machining Solutions Discuss Material Machining Problems and Solutions Here.
Old 05-08-2010, 11:16 PM
alexismeinto is on a distinguished road
ABS or Delrin?
Hi everyone,
I'm looking to build some small devices. I'll be turning most of it by hand with a small lathe. The outer diameter is about 15mm, with a central 10mm hole and a few 1-3mm holes drilled throughout the body.
I need a material that is, first most, light weight. That seems to point to ABS or maybe Delrin. Then for the machinability I'm tending towards Delrin.
Any other suggestions? Will ABS give me trouble with welding-chips unless I flood it with coolant?
Old 05-08-2010, 11:27 PM
judleroy's Avatar
judleroy is on a distinguished road
In general abs machines poorly and is not good in mechanical applications because it deforms when heated.
Old 05-08-2010, 11:30 PM
Is there an alternative to ABS & Delrin that has the low-mass but machines well?
Old 05-09-2010, 01:11 PM
Nadiel's Avatar
Nadiel is on a distinguished road
Special plastic
Hello. I think the best material is ERTALYTE TX. View schedule with the coefficient of friction.
http://www.alperton.com/alperton/Mai...20Friction.htm
Old 05-09-2010, 07:40 PM
I don't think that material is readily available from my suppliers (e.g. mcmaster-carr).
I'm more inclined to choose the best out of these materials (the best in terms of mass, machinability, and cost):
-ABS
-Delrin (Acetal)
-Acrylic
-Nylon
-PEEK
-PTFE
...etc...
(see http://www.mcmaster.com/#plastics/=70qy0i for more)
Old 05-09-2010, 09:46 PM
mactec54 is on a distinguished road
alexismeinto
Go with your first choice Delrin, the best of what is in your list is the Peek but the cost
you may not want to pay for your parts
The Ertalyte TX , the TX means it has lubricant added & is great for bushings etc, Ertalyte by itself does not have lubricant added & is slightly better than Delrin for some things
The order of the best to machine from your list
Delrin Peek
ABS Acrylic
PTFE
Nylon
Mactec54
Old 05-10-2010, 07:48 PM
Thanks so much!
What would you say is an approximate wall size thickness for a Delrin? Say the minimum diameter of a cylinder? Or, if you prefer, the minimum wall thickness of a bored cylinder?
Thanks again.
Originally Posted by mactec54 View Post
alexismeinto
Delrin Peek
ABS Acrylic
PTFE
Nylon
Old 05-10-2010, 08:15 PM
alexismeinto
It depends on what your part is for, & how much strength you need for your part, that will determine the wall thickness
Mactec54
Old 05-10-2010, 08:18 PM
Fair enough. I'll give it a try and see.
Hopefully I can get a 1.5mm wall size with reasonable rigidity.
alexismeinto
Old 05-11-2010, 02:06 PM
alexismeinto
That is easy to do, .1mm wall is when it gets a little trick just did some at .8mm wall
Mactec54
  #11   Ban this user!
Old 05-11-2010, 02:42 PM
alexismeinto
Thanks Mactec.
Do you recommend using coolant when turning small parts (15mm stock) from Delrin?
I do my machining at home so I try to limit my coolant-use. Will a little bit of auto-oil or WD-40 work fine?
  #12   Ban this user!
Old 05-11-2010, 04:17 PM
alexismeinto
You should not use auto oil,it is not designed for use as a cuttng or machine lub,But WD-40 will work quite well for finishing cuts, if you can't have flood coolant, You should use coolant for cutting almost everything, it's better for tooling, better for finish & for stress free machining
Mactec54
Delrin Nut donmoran Linear and Rotary Motion 0 02-05-2010 12:20 PM
Is this Delrin/Acetal? HackMax Benchtop Machines 4 06-20-2009 07:29 PM
Delrin fourperf Haas Mills 17 04-29-2008 07:52 AM
Delrin patriotswan General Metalwork Discussion 5 03-29-2007 09:04 PM
Need help with Delrin Marc DIY-CNC Router Table Machines 9 05-26-2005 12:32 PM
