| General Material Machining Solutions Discuss Material Machining Problems and Solutions Here. |
Hi, I´m new in the forum, thanks to let me be a part of it. ![]() I´m looking for info regarding acrylic engraving. My goal is to make A1 size slim led panels. So far I know they use very powerfull led strips and an optic acrylic wich is engraved with a "v pattern". This grooves are very thin (0.1 mm width and less than 0.1 mm deep aprox) and they are very close from each other (1.5 mm aprox). I´m not sure that this grooves are done with a laser, o any rotating device. I think they are done by kind of scratching tool attached to a router. Has anybody any idea were to find or haw to make a tool like that or any other way to do this V cutting ? Thanks in advance. |
Hi Artillero I engrave acrylic, aluminum, G10 glass and all kinds of plastic at work. I use whats called a 60 degree engraving tool, you can get them in all dia. and with V shape or round shaped ends. They are made out of carbon steel. You can probably get them werever they sell machine tools and end mills. hope this helps |
__________________ A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org |
| Hi Artillero, I think what you are describing is called 'drag engraving'. I have posted a video of a tool I made to do this in acrylic in this post: http://www.cnczone.com/forums/showthread.php?t=104920 The first video shows me engraving acrylic but with much more pressure than you would use to get a very fine line. The tool is sprung so you just don't press it into the plastic so hard to get fine lines. Cheers, Bob. |
| Engraving acrylic, which bits | LJN | General Material Machining Solutions | 4 | 05-10-2010 06:15 PM |
| X2 Milling and engraving acrylic | Jay C | Videos | 2 | 10-09-2008 11:47 PM |
| i need a test engraving in acrylic | j9k | Laser Engraving & Cutting Machines | 0 | 02-21-2008 11:26 AM |
| Acrylic | blfuller123 | DIY-CNC Router Table Machines | 3 | 12-28-2006 08:15 AM |
| Acrylic | Mike7 | Vacuum forming, Thermoforming Etc | 2 | 10-30-2006 10:16 AM |
