Results 1 to 12 of 12
Thread: abs cutting help needed
    Jan 2007
    kuwait
    hi evry one
    Trying to cut abs material on cnc laser (300 watts), i had tough experience, i got a burn effect on the back side of sheet and melting on the edges, i m searching of help who hav experience cutting abs sheet, i would appreceiate any help or information bcoz my boss very interested in this process
    Registered Litografa's Avatar
    Jul 2008
    Lithuania
    What is thickness of material? Do you use vector table? Is it possible add gas into cut area?
    Jan 2007
    kuwait
    only 3 mm . wht u mean by gas
    Jul 2008
    Lithuania
    I mean add gas (CO2 or any available inert gas) into cutting area. Really ABS is not perfect material for laser cutting
    Mar 2010
    not a smart idea to even cut abs plastic when it burns it creates chlorine gas which is deadly to the operator and corosive to the mach.
    Jan 2007
    kuwait
    Really causing foul smell, its true
    Jul 2008
    Lithuania
    bklompy - are your sure that ABS contain PVC? I have got samples of engraving laminate from China and they say that this plastic is made from ABS and acrylic, do not contain PVC and good for lasering. But during tests it was PVC smell
    Dec 2008
    ABS is a thermoplastic so it will melt and decompose unlike Acrylic that will vaporize. The cut edge even with an assist gas is never going to be great, but with sufficient power it may be acceptable.
    It is true that many laser laminated use an ABS core, it provides flexibility in the panel and also resists the laser and self heals so you get a nice engraving at a constant depth.
    It will not generate Chlorine gas or the resulting Hydrochloric Acid and is laser safe, just not laser friendly.
    Zax.
    Jul 2008
    Lithuania
    Zax - but how I can test EXACT PIECE OF PLASTIC for PVC-free? Supplier can say anything, but reality could be .....
    Feb 2009
    Scotland
    PVC test
    Gentlemen.
    Please refer to the Bilstein test.
    its not 100% but will positively identify suspect materials with chloride content.
    http://rarenotes.net/beilstein.html
    regards
    KPB
    Jul 2008
    Lithuania
    Thank's - this will be my first task for tomorrow morning as today we spent whole day trying to find +/- true answer DOES THIS PLASTIC CONTAIN PVC
    Dec 2008
    Request an MSDS from the supplier, if they don't have one or you doubt their word I would find an alternate and reputable company.
    As a note. ABS is a styrene and may be a carcinogen (although what isn't) but in addition it has other side effects so ensure you have suitable fume extraction.
    Zax.
    1. Newbie- Hi and help needed cutting white acrylic!
      By craig3000 in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 02-28-2010, 08:28 PM
    2. Problem- Inconsistent EPS Cutting help needed
      By X-15 in forum CNC Wire Foam Cutter Machines
      Last Post: 01-06-2010, 07:18 PM
    3. What cutting tools are needed.
      By stitchlips in forum WoodWorking
      Last Post: 05-21-2008, 11:20 PM
    4. Plasma Cutting needed
      By Gledhill in forum Employment Opportunity
      Last Post: 09-25-2007, 12:27 AM
    5. Cutting advice needed
      By ninauk in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 11-26-2006, 06:33 PM
