Results 1 to 10 of 10
Thread: Y axis cannot move up...
    Nov 2009
    Indonesia
    i'm a newbie... need help on my CO2 laser machine... my problem is i cannot move up the laser head to the y axis, but the x axis can move left and right just fine... whenever i move the laser head up no matter how far up, it automatically move down to the bottom of the y axis...
    anybody please can help me? thank u very much.....
    Dec 2008
    Does your machine have limit switches?
    If so, perhaps the Y-axis upper limit is faulty.
    It could also be caused by a driver problem, but if the machine initializes and moves to the home position it is most likely ok. Some machines have independent home and limit switches, so just because the home switch operates it doesn't mean the limit isn't stuck, and during initialization the limit may be ignored.
    Zax.
    Nov 2009
    Indonesia
    Dear Zax,
    My machine doesn't have limit switches... And the machine also work and start correctly even it always move down to the bottom of y axis... It just doesn't wanna move up, so I cannot move it to the designated area and start from there... I already checked and tested everything, the software did work a bit slow though, then I uninstall and reinstall the software, and nothing changed, still the same... I really meet dead end here..
    Other helps are greatly appreciated and mostly welcome... And thank u zax for the comment and suggestion...
    Joe
    Feb 2005
    Is the up switch bad on the laser? You didn't say what software your machine uses, but some software has up down left right controls on the computer screen also (LaserCut software does), have you tried the controls on the computer screen (if it has them) and those do not work either?
    Just trying to eliminate possible problems.
    Skip
    Dec 2008
    So the machine moves + and - in Y axis when running, but you just can not 'jog' the machine manually?
    That would sound like a switch problem as Skip suggested.
    Is this a home made system?
    Zax.
    Feb 2005
    After reading his first post again, he says: "whenever i move the laser head up no matter how far up, it automatically move down to the bottom of the y axis..." So now I am wondering if his down switch isn't stuck?
    Would that cause this problem Zax?
    Nov 2009
    Indonesia
    My machine can do both laser cut and engraving, I bought the machine from china and it worked perfectly over the past four years... I bought it from the company called "Hongfei Laser", it uses its own software called "Lasermark" and the software doesn't have control on the computer screen. I emailed the company yesterday and haven't got any reply yet.
    Yes, I cannot "jog" the machine manually but the machine can moves + and - in Y axis when running.. Strange right?
    Maybe Skip is right... But how to check the switch as the access to the switch panel seems unreachable from my machine? This machine is 2005 made, so it's old and compares to the newer machine that has "easy access", the housing interior in this machine is quite unpractical..
    How do you usually access to your switch panel?
    Thanks..
    Joe
    Feb 2005
    Hi Joe,
    My machine looks like this one: http://www.wklaser.com/html/403.html
    And the control panel screws are accessed from underneath the panel. You get at them with the lid open. Yours may be completely different, I don't know. And I have no idea how, or if, you can even repair them. You might have to change the whole control panel.
    My control panel has a plastic overlay on it. If I were to peel that off I would be able to see the direction buttons (I think). Maybe one is stuck, or maybe something in the button circuit is bad. That is beyond my knowledge unfortunately.
    But the jog buttons are disabled when you are running a file, so that explains why it runs normally when running. It sounds to me like a button, or button circuit issue. Hope the company gets back to you soon.
    Sorry I can't be of more help.
    Skip
    Nov 2009
    Indonesia
    ok i will try that...
    and skip, thanks a lot for your helps.. greatly appreciated..
    Joe
    Feb 2005
    You are most welcome, Joe. I wish I could be more help.
    Let us know how you make out with it.
    Skip
    1. Need Help!- All axis will not move
      By SELECT in forum Fadal
      Last Post: 09-30-2009, 11:37 AM
    2. how to move the Z axis on a pendant
      By cob in forum Mach Mill
      Last Post: 12-18-2008, 03:49 PM
    3. how to move the Z axis
      Last Post: 08-22-2008, 08:56 PM
    4. What method did you use to move the x-y-z axis?
      By widgitmaster in forum Polls
      Last Post: 01-07-2008, 02:35 AM
    5. G91 B axis move?
      By DocHod in forum G-Code Programing
      Last Post: 11-02-2007, 12:56 AM
