Results 1 to 6 of 6
Thread: help choosing airblower for sucking fumes away
    Dec 2006
    Belgium
    I'm looking for an airblower to suck the fumes away from the underside of the workpiece.
    I've looked around but there are so much different blowers.
    Anyone can give me advise on the power or volume (cubic meters of air) I need?
    Cutting area is about 600x1200mm.
    Thanks!
    Dec 2006
    Belgium
    I've found these pictures of a company that makes a laser cutter/engraver with a bed size of 1200x900.
    They use this airblower:
    Anyone can estimate the power of this one?
    Registered Litografa's Avatar
    Jul 2008
    Lithuania
    For GCC lasers with table 910x680 mm we reccomend 1 kWt pump (500 cub.m/minute). But pump on picture is more powerful - I think 2-5 kWt. The possible reason is that GCC laser have closed type construction, or big chinese lasers have open table construction, so they need more powerful suction.
    Anyway there is mistake on pictures - you need filter between laser and pump. We usually put air filter from trucks.
    PS Where you found this pictures? Looks like old soviet military pump
    Dec 2006
    Belgium
    this is the site where I found it:
    http://iehk.net/index.html
    Dec 2006
    Belgium
    Is there another way to suck away the fumes?
    These 1kw pumps seem pretty expensive.
    Right now I have air assist coming out of the nozzle.
    Could I add a second hose next to the nozzle that sucks away the fumes?
    Or would this disrupt the air assist too much?
    thanks
    Feb 2005
    Quote Originally Posted by MatD View Post
    thanks
    I don't think a second hose next to the nozzle would work very well. You wouldn't get the volume of air flow and the smoke would be building up in the cabinet while waiting to exhaust.
    I have a 600x900 machine and I use the 1200 cfm blower from my dust collector.
    Something like this would work for you, or here is a cheaper one with more cfm's.
    1. PVC fumes?
      By Teyber12 in forum Safety Zone
      Last Post: 05-20-2013, 05:11 AM
    2. chip removal by vacuum sucking
      By rajanish in forum Safety Zone
      Last Post: 03-22-2011, 10:37 AM
    3. Sucking instead of blowing?
      By LuAn in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 05-14-2009, 08:37 AM
    4. Breathing fumes...
      By Tebis in forum General Metalwork Discussion
      Last Post: 09-06-2006, 07:23 PM
    5. EPS foam dust or hot-wire fumes?
      By Charlye in forum Safety Zone
      Last Post: 03-16-2006, 05:19 PM
