The DVD diodes are easiest, since you can just install them into a standard (meaning cheap) housing which has the focus lens. Power supply requirements are also lower so cheaper too. The downside is as you said, the cutting power is very low so not much use but they can be used for engraving on wood etc.
You could use a 1W diode, but make sure to price up the power supply and required lens before jumping in.
Zax.
LinkBack URL
About LinkBacks
