It sounds like your alignment isn't correct.
Have you checked that the beam enters the center of the final mirror / lens assembly at the maximum distance, center and minimum distance?
It sounds like the beam is slightly off and not being focused correctly into a single beam. You may also check the lens is clean and seated correctly as this could also produce the symptoms you describe.
Once adjusted you'll enjoy the machine.
Zax.
LinkBack URL
About LinkBacks
