Results 1 to 4 of 4
Thread: HX40B - what are the best settings
    Jul 2009
    Question HX40B - what are the best settings
    I recently purchased a HX40B to cut felt for my business and I was wondering if anyone else has had luck with cutting felt without burning the edges. If so can anyone give me advice on the correct power/speed etc. or even felt type. 100% acyrlic, wool blend etc to use.
    Thanks for any help or advice possible.
    Dec 2008
    Shazz,
    I've cut 1/8" cheap felt (synthetic blend) and the results were excellent.
    I suggest using 2-passes of 2W @ 2cm/s, the majority of cutting is done with the first pass and the 2-pass cleans up the remaining fibers.
    If you have 1/4" you could try increasing the power but at some point you'll need to use additional passes rather than power or you'll get scorching.
    Zax.
    Feb 2010
    SPAIN
    Hi everybody. What about best settings for rubber stamps engraving? Thanks
    Dec 2008
    It depends greatly on the rubber, but in my experience it is best to use a higher power and speed combination.
    I would suggest to start around 50% power @ 10-12cm/s. Air assist will really help too, or an improved exhaust fan.
    Zax.
  1. Need Help!- hx40b
    By nazirabd in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 05-19-2010, 03:38 AM
  2. DSP settings
    By rocabig in forum Excitech routers
    Last Post: 12-04-2009, 04:46 AM
  3. Need Help!- Mach3 CV settings vs. G-100 Plugin CV settings
    By Bfarn in forum Machines running Mach Software
    Last Post: 12-17-2008, 11:45 AM
  4. Settings
    By piedpipertraps in forum DynaTorch
    Last Post: 10-15-2008, 06:30 PM
  5. dnc settings
    By jamesr in forum Fanuc
    Last Post: 02-02-2006, 03:13 PM
