Page 1 of 3 123 LastLast
Results 1 to 12 of 26
Thread: LaserPro Spirit Drivers (LPT)
    Apr 2009
    Ireland
    Question LaserPro Spirit Drivers (LPT)
    I am having difficulty sending files to our LaserPro Spirit from my Windows XP PC. My PC crashed so I had to reinstall everything. I installed the driver software, from the original CD, and I can select the cutter from Adobe Illustrator but when I click on print nothing happens. There is nothing in the print queue and windows does not report any errors. Am I forgetting something obvious.
    I would really appreciate some help on this as its driving me mad!!
    Registered Litografa's Avatar
    Jul 2008
    Lithuania
    First of all why you do not ask your supplier ?
    Please note that you must install driver first (laser schould be NOT CONNECTED), and only when driver is installed, you can connect laser, swith on and plug-and-play will find equipment.
    I hope you have checked ports and everything is OK? As I understood right, you are working via LPT? If YES, why you don't use USB?
    Apr 2009
    Ireland
    Smile Laser Pro Spirit
    Thank you very much for your help.
    We are trying to contact our supplier at the moment.
    I've tried both LPT & USB and on more than one PC, but no joy. The unusual thing is that the Spirit drivers appear to be installed correctly. There are no errors during the installation and its listed in the printers folder with the correct port. When we try and send a file its appears to be working, i.e. no windows errors, but nothing happens on the Spirit.
    Is there something wrong with the configuration of the printer? Is there something we need to change? Is there a utility program that would allow us to test the communication between the Spirit and PC?
    I would appreciate any advise you could offer
    Oct 2009
    Kosova
    Hi tonyryan1968 did you solve your problem, since i have the same problem with my machine. It was working fine but now im not able to send anything to the machine, and sometimes i get an error message saying that my PRINTER SPOOL SERVICE is not active. I go manually activate it, i reinstall all the driver but still nothing. I have contacted my supplier as well and i am awaiting an answer.
    Jul 2008
    Lithuania
    Hi, Arben,
    Generally installation of laser consist from few steps
    1) Disconnect laser from PC. Insert original CD into PC and install USB driver.
    2) Connect laser and PC with cable, switch on laser and when PC will detect USB device follow instructions to install this USB device
    3) Go to CONTROL PANEL and start procedure ADD NEW PRINTER. When PC will ask drivers - show path to driver section on GCC CD. Follow PC instructions.
    4) And finally after all process check USB port settings (schould be USBGCC port created)
    Oct 2009
    Kosova
    Hi Litografa, Thanks for your quick reply.
    I have done this procedure a couple times now since i'm an experienced IT for more than 7 years now. i have reinstalled my whole system with a new copy of Windows (before i had XP, now i installed windows7) and i get the same error message, and the laser doesn't receive anything. 2 days ago my laser worked just fine i engraved with it a couple things, than the next day i just got that message. Could it be that something is wrong with the laser engraver itself ?
    Jul 2008
    Lithuania
    What do you mean Windows7 - Vista?
    Oct 2009
    Kosova
    It is the Newest Windows which just recently was released, it's newer than Vista.
    Jul 2008
    Lithuania
    IMHO problem is in driver, try Vista driver from our site http://www.litografa.lt/index.php?aid=150 but I am not sure that it will work. Better return to XP
    Oct 2009
    Kosova
    Now i am able to engrave with 125DPI and 250DPI but as soon as i go with 300 or more DPI i am not able to do anything. I need HELP on this one
    Jul 2008
    Lithuania
    Really I hate this new Microsoft OS - when I unfortunately bought notebook with Vista - I can't print even on office laser HP one month because driver arrived later than OS
    Oct 2009
    Kosova
    Thanks Litografa.
    I will give it a try with the new drivers. I am able to engrave now only with 125DPI and 250 which is TOO low for the things i do. i usually engraved (until 2 days ago) with 500 or 600 DPI, which is needed in order to keep my current work quality. I Hope that the new drivers will help me doing so. BTW i had this same problem on my XP OS, and i thought that my OS was corrupted or something, and since i got a new Licensed copy of Windows 7 i thought i would give it a try.
    one more question, do you have any tutorial or something how do i put the new Firmware on my laser engraver?
  • Page 1 of 3 123 LastLast
    1. GCC / LaserPro Dealer Supplier Distributor in Australia
      By Esmae in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 01-21-2009, 05:04 PM
    2. Need Help!- New Laser pro spirit.
      By desibrown in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 11-10-2008, 03:46 PM
    3. Laserpro lasers up for discussion
      Last Post: 03-28-2008, 01:06 PM
    4. spirit houses
      By charper in forum Machine Created Art
      Last Post: 10-22-2007, 08:51 PM
    5. Laserpro Explorer / Pinnacle ZX & Solidworks
      By obrockmeier in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 05-11-2007, 05:15 AM
