Results 1 to 2 of 2
Thread: Laser cutter for PCB stencils?
    Mar 2009
    Hi there,
    I am planning to buy a small laser cutter. I want to use this laser cutter/engraver to cut plastic/mylar sheets. These sheets of plastics are of standard size (8.5x11 inch) and they have a thickness of 1-4 mil (0.03-0.10mm).
    I want to use these sheets of plastics for stencils to be used for printed circuit boards.
    I have looked at some Chinese and this one looks fine to me. (See link below):
    http://www.hflaser.com/Desktop-Laser-Engraver.html
    this one also looks good:
    http://cgi.ebay.com/Laser-Engraving-...ayphotohosting
    Do you have any suggestion, and advice? I have never worked with lasers before. I need the cuts to be very precise, clean, and not burned.
    The stencils I want to make are similar to the one in this link:
    http://www.pololu.com/catalog/product/446
    Regards
    Dec 2008
    Those units are similar to the unit I have:
    http://www.mbkpinternational.com/art...r_engraver.htm
    I paid less than $1500 shipped to the door for this unit and have been happy with the results.
    It came with a 2" FL lens which produces a pretty small spot size, should be acceptable for your application. I would check with the seller to be sure.
    Zax.
  1. CNC Laser cutter versus CNC Plasma cutter?
    By squale in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 01-12-2013, 10:57 PM
  2. Hello new here. Want to buy a laser cutter
    By smartresins in forum Want To Buy...Need help!
    Last Post: 09-06-2011, 03:04 AM
  3. help with new laser cutter
    By shellglen69 in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 09-18-2008, 08:28 AM
  4. Need Help!- ctr laser cutter
    By teddybear in forum Want To Buy...Need help!
    Last Post: 08-30-2008, 12:33 PM
  5. Why buy a Laser cutter when you can modify a laser engraver.
    By spacifique1 in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 08-13-2007, 03:39 PM
