Results 1 to 3 of 3
Thread: Laser cutting craft foam, have you done it?
    Apr 2005
    I do not have a laser cutter. But I was wondering if anyone has used their cutter to cut craft foam? This stuff... Craft Foam
    Is it easy and fast to cut, a pain in the behind? Thanks in advance for any information!
    Rick
    steelandcopper.blogspot.com
    wakingbearstudio.etsy.com
    Dec 2008
    Rick,
    EVA foam (Foamies) cuts quickly and easily, but as with other thermoplastics it will melt so shapes may not retain sharp corners or small detail.
    It is not as bad as expanded foams though and you can get very acceptable results.
    Depending on the application I either de-focus slightly (above the material) or use 2-passes at lower power to produce better results.
    Zax.
    Apr 2005
    Quote Originally Posted by zax15uk View Post
    Rick,
    Zax.
    Makes sense. Very good information. I think you have answered my questions. It sounds like it would work fine for my needs. Now I need to get my patterns together and find someone who can do some test cutting
    Thanks!
    Rick
  1. New Machine Build- CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!!
    By oliver9866 in forum Engraving Machines
    Last Post: 12-15-2010, 03:44 PM
  2. Laser Cutting Foam
    By James80 in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 03-17-2009, 09:21 AM
  3. ITOP--CNC ROUTERS, LASER ENGRAVERS, LASER CUTTING MACHINES, CNC PLASMA CUTTERS
    By oliver9866 in forum Product and Manufacturer Announcements
    Last Post: 10-17-2008, 11:17 AM
  4. Foam cutting CNC
    By CNCadmin in forum DIY CNC Router Table Machines
    Last Post: 12-07-2006, 02:00 PM
  5. CNC Foam cutting HELP!!!
    By Flight in forum General Electronics Discussion
    Last Post: 10-27-2003, 08:24 PM
