Results 1 to 4 of 4
Thread: laser engraving machines
    MBG
    MBG is offline
    Feb 2005
    uSA
    I am looking to get a laser engraving machine. I come from a CNC mill and lathe background.
    Please is there anybody on here I can talk to regarding this machine?
    thanks a lot.
    Registered Konstantin's Avatar
    Feb 2004
    Mexico
    You are in the right place however you need to be a bit more specific in terms of budget, desired wattage and purpose.
    MBG
    MBG is offline
    Feb 2005
    uSA
    Quote Originally Posted by Konstantin View Post
    My budget would be under 3,000 US dollars.
    I don't understand wattage. I seen them range from 40watts to 80 watts.
    I would like to do dog tags and glass.
    I seen one for sale on ebay for 2,000 a 40watt but the glass I want to do is glass cups which can range 3" diameter to 5-6" diameter. This machine on ebay had a depth max of 2.85".
    Do you know of any manufacturers that provide the depth without adding to much to the cost?
    Dec 2008
    In that price range you'll be looking at either a used US machine (Epilog, ULS etc), or a Chinese system.
    The Z range (max depth) is just the amount of table travel up/down, the laser depth of field will be much less so for curved surfaces you'll be looking for a machine with a rotary attachment.
    40W should be sufficient if you are thinking of painted or anodized dog tags.
    Zax.
  1. laser engraving & cutting machines / factory
    By mandyfang in forum Product and Manufacturer Announcements
    Last Post: 12-02-2010, 09:17 PM
  2. Need Help!- versa laser, laser engraving
    By cadmaniac in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 04-25-2010, 03:30 PM
  3. ITOP--CNC ROUTERS, LASER ENGRAVERS, LASER CUTTING MACHINES, CNC PLASMA CUTTERS
    By oliver9866 in forum Product and Manufacturer Announcements
    Last Post: 10-17-2008, 11:17 AM
  4. Engraving photographs with CO2 Chinese laser machines?
    By GDP in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 08-19-2007, 09:01 PM
  5. CNC engraving machines
    By ice in forum Product and Manufacturer Announcements
    Last Post: 10-29-2006, 10:40 PM
