Hi Steve, Sounds like an electronic component failure in the intensity control circuit. Do you have a schematic you can post? Have you tried drawing several small filled rectangles each with varying intensity on a piece of scrap plywood? If they all come out the same then it is my guess it is the intensity control circuit. To get around the problem can you increase the speed for the sections that are marked too deep/dark? If the intensity is stuck at one level, then more speed should help prevent the burn-through or over-burn. Dave
LinkBack URL
About LinkBacks
