Results 1 to 4 of 4
Thread: Lasercut 5.1 language file
    Apr 2006
    Post Lasercut 5.1 language file
    I am using Lasercut 5.1 and would like to fix some of the language texts in the dialog boxes. The language.ini file is used to set some of the text strings displayed in the dialog boxes and menus. Does anyone have a list that describes what values correspond to string locations? I am specifically interested in changing the website, company, telephone, copyright ... etc.
    Also .. The "help" command does not work. It should cause some messaging or start a session of windows help.. Anyone know where the file designator its? I am guessing it would also be found in part of the language.ini file.
    Thank You,
    Ray
    Feb 2005
    I've got LC 5.0 and in my language.ini file it's lines 176, 177, 178, and 179. It looks like just plain text entries will change what is shown on mine.
    If I click on Help, I don't get anything either.
    Skip
    Dec 2007
    Poland
    the website, company, telephone, you can change in syscfg file, not in language.ini
    There is separate section [Company Name](or something like that)
    But be carrefull,do not change any line you are not sure what you realy change.
    I succesfully changed CompanyName,website.... in Lasercut 5.1,after instalation.
    The ini files you'll find in folder with main aplications.
    I have te same problem with Help too.
    Grzegorz
    LC1280 80W
    Registered kewlkiwi's Avatar
    Oct 2004
    New Zealand
    Quote Originally Posted by grzegorz1965 View Post
    the website, company, telephone, you can change in syscfg file, not in language.ini...
    I can confirm that it's the same file for LS 5.0
    Bob
  1. Lasercut 5.0 and 5.1
    By avetek in forum LaserCut
    Last Post: 12-26-2012, 01:16 AM
  2. LaserCut 5.0 and Windows Vista?
    By glintid in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 12-09-2009, 04:07 AM
  3. Lasercut software
    By terry32506 in forum Engraving Machines
    Last Post: 07-28-2009, 12:25 AM
  4. Ayuda con LaserCut 5.1
    By anibald23 in forum Spanish CNCzone
    Last Post: 08-12-2008, 05:50 PM
  5. Not really a log... LaserCut router
    By Guldberg in forum CNC Wood Router Project Log
    Last Post: 07-04-2008, 07:51 AM
