Is the tube "lighting" when you test fire ?
is the water flowing the correct way ?
Is the water level o.k
How is the h.t connection to the tube?
Try these first
Thanks Chris
I have 60W laser tube in my laser engraving machine and few days ago they immediately stop working correct:
I do not sure is it problem in tube or something else.
when i press on machine test button normally I have max laser power ( on instrument, I think, 25 mA) but now I have about 6 mA. Do you think That problem is in laser tube or not. Laser tube has about 300-400 working hours.
I am try reinstall software but same result. Manufacturer of machine said that problem must be in tube, but...
Try these first
Thanks Chris
Check the power supply,
yes but not strong like before, end only on manual control on full power.HTML Code:Is the tube "lighting" when you test fire ?
I`m always checking water in tube and waiting if have some air bubbles that gone, from that reason I haven`t back cover that I can everytime check tube.HTML Code:is the water flowing the correct way ? Is the water level o.k
as I said machine working normally two day before and only one day stop, I try cut some plywood for new box and when I try cutting I have seen that power is too small and then I try with test button and sow that I can took more then 6 mA....
what is "h.t"HTML Code:How is the h.t connection to the tube?
how can I check power supply, you think laser power supply I suppose, because other parts on machine working OK.HTML Code:Check the power supply,
You mention you were cutting plywood before the machine lost power... have you checked the optics? A lot of plywood glues can foul the optics...
Hi-TecDesigns.com -- Automotive Lighting Systems
I cut that plywood many times and problem... problem is in power of laser; normally I set power on 85 - 90 % and speed 15- 20 and working well and on instrument I have about 25 mA and now I have only 6mA !
look that video:
[ame]http://www.youtube.com/watch?v=8iiZj1FOmJ0
is it that end of tubes life ?
I am changed laser tube end laser working fine but...
