Results 1 to 4 of 4
Thread: Problem cutting a round circle
    Feb 2008
    nl
    Problem i think is with coreldraw?
    if ai draw a round circle and export it as a plt file
    and import it into the great lasercut 2.0
    it will cut the circle like it has edges.
    wierd thing is if i use vector files i allready purchased they seem to be fine.
    i hope i posted this in the right section...
    Sep 2007
    Smile Curve Resolution
    Sandor,
    After saving as a plt file another window will appear. Go to the 3rd tab Advanced. Save curve resolution as .001. Should be fine. Jim
    Rabbit Laser HX6090SC
    Apr 2007
    Colombia
    Yes, plt circles and curves sent from corel leave that segments. try autocad.
    other way in corel when you save the file in advanced you can change the length of the segments
    Feb 2008
    nl
    Thanks gents
    that soved indeed the problem
    i remember seeing it also happen with my cnc machine
    when i plotted some vinyl , i thought it was the resolution of the stepper motors..
    misteriously now i setted that setting to 0
    and now all is fine
    thanks for the info..
  1. cutting curves, circle, radius?
    By _taz_ in forum Benchtop Machines
    Last Post: 02-08-2008, 12:57 PM
  2. Milled Circle Not Round?
    By b0gh0s in forum Benchtop Machines
    Last Post: 12-01-2007, 09:16 PM
  3. circle cutting wizard problem
    By kb7vms in forum Mach Wizards, Macros, & Addons
    Last Post: 11-06-2006, 12:14 AM
  4. Repeated circle not round.
    By SCCoupe in forum DIY CNC Router Table Machines
    Last Post: 07-19-2006, 10:32 PM
  5. Problem cutting a circle..servo setup
    By powerfade in forum DIY CNC Router Table Machines
    Last Post: 03-19-2006, 02:43 PM
