Page 1 of 4 1234 LastLast
Results 1 to 12 of 38
Thread: Help Needed With WKLaser LC6090
    Dec 2007
    New laser cutter having intermittent problems with datum. Wants to go beyond 'home'; up and left arrows not working at all; down and right try to take it home. Is this possible problem with firmware? Or the MPC6515 driver or card itself? Has anyone experienced this? Have reloaded driver and software many, many times. A few times it got it going; now nothing. Suggestions?
    Feb 2005
    LC6090
    Hello,
    I have an LC6090 also but it's the USB setup, no card. I would try to remove the card and re-seat it, make sure it's all the way in the slot and the contacts in the slot are lining up with the contacts on the card.
    Do a search for posts by Flyguy007. He also has an LC6090 and had some trouble getting his card working correctly, but eventually did. He posted some information about it.
    Registered MacGyver's Avatar
    Oct 2007
    Also make sure the limit switches are aligned properly and not wired in reverse.
    Hi-TecDesigns.com -- Automotive Lighting Systems
    Dec 2007
    Also have USB set up; MPC6515 is in machine. You are supposed to be able to reload firmware through the USB flash drive; doesn't work. Hangs up at either system starting or downloading progress 0%. When connected to PC through USB cable, we can download a processing file, but the file won't run because datum is not working.
    Feb 2005
    Here's what works for me... have your computer running and the USB cable connected and turn the laser on. Wait for it to go to the start screen. Start up the LaserCut software. Click on the printer icon at the top area of the screen. Click the Stand Alone tab and click on the Download Config button and see if the machine beeps that it has received the config file. If it beeps then you know the USB connection is good.
    On mine, I didn't want it to do the datum thing every time I started it up, so under File, Machine Options (I think that's what it says, I'm not in the shop), click the first choice on the list and I unchecked Auto Datum. But after I did that I couldn't send files to the machine. WKLaser had me change a speed setting from 20 to 8 (slow jog speed) and that's all it was. It has worked great ever since, and the laser head stays put now when powering on.
    But anyhow, to use the USB thumb drive to load the config file, and cut files too, onto the laser you have to export the file to the thumb drive using the LaserCut Stand Alone window because I think it adds more than one file. Like to load a cut file with the thumb drive I think there needs to be 3 separate files (or maybe 2) before the laser will recognize it. It's much easier to just use the USB cable to send them, if possible.
    Sorry if you know all this already. If you need more info or need a copy of my config file to look at to make sure yours is the same, just let me know. I will brave the snowstorm we are having and walk out to the shop and make a screenshot of the config settings.
    Also, MacGyver had a good point about the limit switches. I can let you know how mine are wired if you want to check that. But first of all, get a good config file to the machine.
    Sep 2007
    Datum
    I had this problem with a Rabbit Laser. On the control card is a jumper, it was in the wrong location. move it over 1 pin to the left. should be all the way over to the left.. If you are looking at the card it is on the left side of the card between the 2 green connectors. Of course this was on a Rabbit Laser. Hope this helps. Also try sawmillcreek.org. Jim
    Rabbit Laser HX6090SC
    Mar 2006
    Deutschland
    if your controller acts crazy like this, it will most likely not recognize the config file youīre trying to download.
    Use a fresh config file, right from a new installation of lasercut50. Donīt make changes to the config, just download the file as it was installed to the machine..
    If the machine does not beep after receiving the config file, do the following:
    Choose/highlight the CFG file in the machines data screen, press enter, then press start. The machine will "run" the config file then (and maybe beep).
    Shut down machine, turn on again and see if problems persist.
    If yes, next thing to do is shutting off machine and checking the wires and connectors on the controller board. Rock the connectors slightly from side to side and make sure they are seated well, look for loose cables. Turn on machine and see if it starts up normally.
    Still not working?
    Next you could flash the controller with the corresponding firmware. This is different from the CFG file process. Normally you donīt have to flash the controller with the firmware but sometimes it can help. Do NOT upgrade your MPC6515 with a newer firmware, itīs good for nothing.
    If you have V4.0.0.15 (see label on the motherboard), I can send you the files.
    After firmware procedure you have to download a CFG file, without it the machine will not work.
    Check your home switches: Turn on machine with laser head in middle of working area and door open. Before the machine reaches the home corner, press switches by hand. If there is no reaction, switches or wiring is bad.
    Check the position of switches.
    Our machine (WKlaser lc1280) is wired nicely but factory installed y-axis switch slightly off position. While homing the laser head (actually the belt tensioner screw) hit the beam /rail on the right side before touching the limit switch. This way the work area was expanded by one Inch to the right side :-) but it was not the way it should be. I moved the limit switch to the left a little bit and thatīs it.
    The home position is in the upper right corner, see if the settings in the config file are correct.
    hope this helps
    stephan
    Dec 2007
    No Luck Yet
    We appreciate all the responses; will try everything this am and let y'all know!
    Well, have tried all helpful tips from everyone. Nothing yet. We do have 4.0.0.15 so Stephan if you could please send files we would greatly appreciate it.
    Dec 2007
    No luck yet, would you mind sending us your files? We do have 4.0.0.15. Thanks!
    Mar 2006
    Deutschland
    here it is...
    Fmw.zip is all you need for the firmware procedure.
    MPC6515_V4.0.0.15User.zip is the whole package. You can try the "Mpc05Ver+M05.exe" app to check the version of your controller board.
    The Rest is manuals, USB driver and so on. You already got these files with your machine.
    I downloaded this a few weeks ago from the website of the conrollers manufacturer.
    They have a new website now which is chinese only; I couldnīt locate the firmware download there anymore.FYI: www.leetro.com
    The old website in english is steill available (at least from time to time :-)
    www.step-servo.com
    They have a newer firmware there; I had no luck with it, machine does better with original firmware.
    Good Luck!
    Stephan
    Attached Files Attached Files
    Mar 2006
    Deutschland
    Larger file doenīt upload...
    I canīt get the larger one to upload. Anyone interested in his pls send me a private message
    regards
    stephan
    Dec 2007
    New Zealand
    Hi to you all.
    My first post and I need help. Have been reading with great interest the comments so far in this thread. I have a new 80W laser, the same as SkipW. USB setup and all. So far the Chinese have been great with trying to get things right but so far we still have not had any success. When we got the laser we followed everything to the letter but nothing. We did find a test file they left on the USB. Downloaded that from the USB direct into the laser and their file works very well. So I can cut a 150mm square or engrave an outline from it. Anything we load in the Lasercut 5.0 or Corel we can down load it to the laser but nothing happens. I have checked the driver as the posts here and it is 4.0.0.15. I can also move the laser around the work table from the computer. I strongly believe it is a software problem with the Drivers and the Lasercut; but not been experienced enough to be certain, so I have asked Smoe for software copies. I also think I may be just setting up the files for engraving wrongly when I am putting them through their final stages before tranferring them to the laser. Any one out there with any thing else that can help would be greatly appreciated.
  • Page 1 of 4 1234 LastLast
    1. Rabbit HX3040 vs. WKlaser LG3040?
      By CanAm in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 02-01-2009, 01:24 PM
    2. WKlaser post a lot of AD here, i bought a WK40 from him...
      By bear08 in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 12-10-2007, 10:29 PM
    3. Help - RedSail C120 or WKLaser LC6090?
      By FlyGuy007 in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 03-12-2007, 10:37 PM
    4. cnc guy needed $$$
      By greatscott in forum CNCzone Club House
      Last Post: 02-25-2007, 11:43 PM
    5. Help needed
      By BlackIbanez in forum G-Code Programing
      Last Post: 11-23-2005, 02:22 PM
