Results 1 to 8 of 8
Thread: Questions about Lasser Cut 5.0
    Nov 2007
    I have this lasser cut 5.0 software
    When I install in my computer at home
    It wont start and says something is missing
    Does the computer have to be connected to the engraver in order to start this program?
    Or
    Does anybody can tell me where can I download this program?
    (I think the one I have is messed up)
    Anyways, any help is greatly appreciated!!
    Aug 2007
    Try Again
    Mine took a while for it to work properly. I do think you need to have the laser on. Try it a couple of times if not I may have an extra copy somewhere in my desk. Make sure you are not using Vista! You could maybe try it on another computer and see if you get the same error.
    Apr 2007
    Colombia
    the 5th download of that software will be the best,
    reinstall it, and reinstall it, these software is a pain in..
    but after a while it works. have the mmanuals in chinese? if not you are a lucky guy, if need I can send also, dont forget to connect the soft dog.
    Luis
    Dec 2007
    uk
    hi, can anyone help me with a software problem concerning lasercut 5.0
    Aug 2007
    Whats the problem?
    Nov 2007
    Quote Originally Posted by ArturoV View Post
    Hi there , I have the same software and im on Vista...Tricky indeed but I got mine working by means of serial port connecting if that helps to say.
    Terry
    Nov 2007
    Quote Originally Posted by Champloo View Post
    Or
    Hi , I have the Lasercut 4.0 version and with that version you have to have the laser engraver on in order for the Lasercut 4.0 to work. I would think that Lasercut 5.0 would be the same as far as that goes. Speaking of which I have been trying to find the 5.0 version...Know where I can get it?
    Terry
    Oct 2007
    Bulgaria
    http://yihesoft.com/ here you can download LaserCut 5.0 but you need softdog to start using this software.
    1. CNC mill questions - thrust bearings, leadscrew mounting, general questions
      By tonofsteel in forum DIY CNC Router Table Machines
      Last Post: 02-03-2012, 04:42 PM
    2. Brass vs Aluminium Vs Steel, questions, questions and questions...
      By alexccmeister in forum General Metal Working Machines
      Last Post: 08-15-2011, 01:40 PM
    3. TM-1P questions
      By kochevnik in forum Haas Mills
      Last Post: 09-26-2007, 09:07 PM
    4. new here few questions
      By joey1117 in forum CNCzone Club House
      Last Post: 01-20-2007, 04:32 PM
    5. 3 questions--ok 4
      By monte55 in forum Machines running Mach Software
      Last Post: 11-02-2006, 09:22 PM
