Would it be possible to reflect the beam out of the tube with a mirror?
Looking for a material to use as a shield to prevent far side of tube being defaced.
Silver has been suggested but prefer a cheaper material.
Will suggest this to the company doing the job.
I see problems holding a mirror in the tube as the mirror would need to be held directly under the beam while the laser head moves about.
Some how would like to absorb the energy.
Thanks for your help.
What size tube? depends on your rate of cut. If you are moving fast, you can use wet sand. If your are moving slow try fire brick
Yes, it could be dangerous. A dual mirror set in a tube similar to a periscope could accurately redirect the beam downwards as it exits. But I don't know what commercial laser tables use underneath to ultimately absorb the beam.
When working with lasers a few years ago we had to use safety glasses, I'm sure that the beam was actualy absorbed by the material- vaguely recall that it contained platinum?
Your best bet would be to contact a laser safety glasses manufacturer and ask em for a free sample. I'm positive that the material will be wavelength specific, so You'll need to know what wavelength you're operating at.
Sorry if this sounds a bit vague.. been a while since I messed about with lasers but I can still remember the smell as I accidently burnt a hole in my thumbnail with a CO2 laser *ouch*.
I love deadlines- I like the whooshing sound they make as they fly by.
Emission technologies use a fire retardant tile inside their box. Look them up and find out what it is.
Quote from their website (hope they don't mind)
quote " The Stainless Steel Vacuum Box under the honeycomb is 8" deep and is Ceramic Lined to absorb excess laser radiation. " end quote.
I am not completely useless.......I can always serve as a BAD example.
What you need is something that will not reflect the laser, but will absorb it. your laser cutting service should know all about this. Usually it is a container, coated or painted black, which is filled with an temperature absorbing material.
I assume by your note you are cutting metal tubing by rotating the tube rather than cutting the tube in one pass like a saw. Are you making stents?
I would think you just need to have a bar or rod, which has been blackened, and if this is really high power stuff, maybe a water cooling system within the rod...inserting the whole thing inside your rotating tube.
Years ago I worked at a linear accelerator research facility, and we used big blocks of copper with water passages cut into them to act as beam stops.
Kiwi,
How much power has you laser got?
If it's only 100 watt or so then maybe a polished piece of Aluminium inserted into the tube will help.
If you give us more info then I reckon someone here will have the answer.
Rich.
Hi Rich
This is not my machine. My son's Company gets rectangle (RHS) stainless cut by a local company. These are for gas fired heaters and the patterned cuts are for the gas to pass through and with fire resistant logs on top to create a log fire appearance. .
The machine is a 4KW Amada FO-4020 NT.
http://www.farra.co.nz/home.html
A present they slide a steel plate inside the tube to prevent the lower side from being damaged.
The steel plates need to be replaced often, unsure exactly.
