Page 1 of 3 123 LastLast
Results 1 to 12 of 31
Thread: Engraving with 80-100W?
    Aug 2007
    I just read a thread that engraving quality on an 80+ W laser can be poor. I assume this is because there might not be as great power control compared to lower power lasers? I expect this might be an issue with the chinese lasers. Does anyone who is not a chinese distributor have any experience with this? I plan to get an 80 or 100 W laser to cut up to 1/2" acrylic but I also plan on engraving paper or very thin plastic. Any suggestions?
    Registered MacGyver's Avatar
    Oct 2007
    While I can't yet speak from experience, I would imagine using a PWM output control rather than simply twisting a power knob is the key here. The typical Chinese laser is controlled by way of the current through the tube... as current is decreased, power control becomes less stable. By running the tube at 100% power but rapidly turning it on/off (i.e., PWM), the "average" output power is decreased, thereby allowing a higher level of control over the etch depth. By stabilizing the output power, beam width is also stabilized, thereby preserving image detail.
    Or so the theory should be...
    Hi-TecDesigns.com -- Automotive Lighting Systems
    Feb 2005
    I have an 80w from wklaser and it engraves just as well as it cuts. The power control is software regulated, not with a knob. It uses LaserCut5 to run it, which isn't a bad program once you get used to it.
    Here's a little box I made yesterday out of 5/32" cherry. I used a little too much power for cutting out the pieces I think, but it's not really as dark as it looks in the pic, and no residue comes off on your fingers. I'm going to power it down a little on the next one. I was surprised how easy the wood cut. Used air assist also. Sorry for the crappy picture.
    I should add also that the box drawing was made for 1/4" material and I was too lazy to scale it down for 5/32", so the finger joints overhang a little. I kind of like that effect though.
    So yes, an 80w can cut and engrave. I don't know how it would do on a portrait like some do on marble or glass, but I didn't buy it for that anyhow. I may have to try that sometime.
    Attached Thumbnails Attached Thumbnails Engraving with 80-100W?-photo_014.jpg
    Mar 2005
    Romania
    your box
    Do you share the dxf of this box? i would like to try it.
    Thank you.
    Zoltan
    Feb 2005
    I got it from the Epilog site on their sample club pages.
    Sample Club
    Lots of neat stuff there. They call the box a music box and it's toward the bottom of the page. It's in .cdr format. If you need a .dxf I can maybe convert it.
    Mar 2005
    Romania
    Thank you very much. I got it.
    Best regards,
    Zoltan
    Registered MonoNeuron's Avatar
    Aug 2003
    I think the issue is that it is too powerful and engraves too deeply. I use 5-10 watts ( from my 35 watt laser ) for glass and anymore blasts the glass away in fragments and if you run your finger over it after you will cut yourself on the shards. I clean it up with steel wool after and this helps. I am still experimenting with different materials and having a fun time trying different things but I would love a 80-100 watt laser for cutting.........so much faster. ULSinc use 2 x 30 watt tubes in their 60 watt machine and stop one of them when engraving but use both of them when cutting.
    I am not completely useless.......I can always serve as a BAD example.
    Feb 2005
    Quote Originally Posted by MonoNeuron View Post
    Hi Mono,
    Maybe all Chinese 80w machines aren't created equal, but with mine I can set the power through the software so low that I can engrave manila folder paper without completely burning through it. The power is adjustable from zero to 100% in LC5 .
    I've been etching glass ornaments with it lately. It does a great job but as you say, you have to buff it a little after etching to remove the jiggers. I use a scotch-brite pad, which works good for me. Do you ever color fill the etchings? I'd like to try that but I don't know what would work the best. I might try masking the ornament then etch it, then lightly spray paint it. Any advice?
    Aug 2003
    Hey Skip,
    The only stuff I have used so far has been " Rub 'n Buff " from Amaco at about $8 AUD for a 15ml tube (which is a lot as it goes a long way. I think there is about 8 colours in their range and it is made up of waxes and fine metal powders and I think they look great. Other people use acrylic paints which also look great, so they say. Head on over to "Sawmill Creek" where you will find a veritable cornucopia of people who have been in the trade for millennia and are willing to give away ALL their secrets for lasering.
    I hope you find something worthwhile to use.
    Rich.
    http://www.sawmillcreek.org/
    Have fun. He he he. More hours of reading.
    Feb 2005
    Hi Rich,
    Yep, I'm a creeker too. It's like a laser encyclopedia, that's for sure. I've seen posts telling of poor results from the rub-n-buff. Maybe it's all in how you apply it though. You seem to like it. I guess I'll order a tube and give it a go.
    Thanks and g'day.
    Skip
    Aug 2003
    I don't like the Blue, antique white or red.
    I DO like the gold and the silver. They seem to stand out a bit more so if I was to suggest one for you to try then it would be the gold. It dries pretty quickly and seeing as though it's made from carnuba waxes etc then I think it would be pretty good in a bathroom where the water and mist would be repelled.
    Just put a small dab on your finger tip (size of a match head) and rub it in until it starts to dry then buff off the rest with a soft cloth. The small amount should cover about 1 1/2" square
    maybe you will like it and maybe you won't. All a matter of taste I think and I wish I had some samples for you to look at.
    I think I will go and do an MC Escher onto a mirror in a minute and see what happens.
    Rich.
    Feb 2005
    MC Escher
    Rich.
    MC Escher is an incredible artist. Please post a picture if you get good results.
  • Page 1 of 3 123 LastLast
    1. Need Engraving Help G47
      By BigBoBo in forum G-Code Programing
      Last Post: 07-04-2008, 04:37 AM
    2. My New CNC engraving
      By dcarr in forum Engraving Machines
      Last Post: 12-22-2007, 06:59 PM
    3. PCB Engraving
      By PaioX in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 07-13-2007, 11:20 PM
    4. engraving on vf-2
      By jprobst in forum Haas Mills
      Last Post: 05-09-2007, 04:54 PM
    5. Engraving
      By camtd in forum Surfcam
      Last Post: 09-05-2006, 11:22 PM
