Results 1 to 5 of 5
Thread: What power is needed to cut thin foam?
    Mar 2007
    Netherlands
    having built a CNC router, I'm now looking to expand it's use. For wood working I will continue to rout, but I often cut (now by hand) Depron, a 3 or 6 mm sheet of some polysomething foam, from which one can build small RC planes (parkflyers). Now my idea is to start of using a laser from a DVD (200 mW, if my research is correct). But is there a theoretical way to guestimate the necessary power? If the prices of the necessary laser is beyond the budget, I might just forget about this for a while...
    Thanks,
    Hugo
    Registered MacGyver's Avatar
    Oct 2007
    I imagine a power density of 5-10 W/mm^2 would be adequate for foam, at least for CO2.
    I ran through some quick calculations, but I'm wondering if I missed a decimal place (or five). A DVD laser diode has a wavelength of around 640nm... good optics might get you to a spot size of around 10-15um. My in-the-head calcs say this is a beam density of 390MW (yes, that's mega!) at that spot size... the advantage of this semiconductor laser over a typical CO2 laser is the wavelength, which allows you to focus to a smaller dot size by a factor of 1,000 (and hence have a higher power density by a factor of 1,000^2).
    Can you achieve that? I don't know, never tried, but I imagine the focal point is going to have a very short length. I'm merely looking at it from a math standpoint, and I have no idea if the power will translate in this way, particularly at a different wavelength than CO2.
    Aug 2005
    Quote Originally Posted by Witsenburg View Post
    Thanks,
    Hugo
    Hello
    We have developed a Plotter with a special knife system that cuts 2.5 -3 mm foam. We are now trying to develop a 6mm blade. This is a little more dificult. The 3mm cuts very well with clean edges and fast. The machine and software will be about $1400 for a 24" machine x any length.
    Mar 2003
    B4 my laser crapped out, I was cutting 1/4 bluecor (fan-fold foam) at 60 ipm at something between 20-40 watts Co2 flowing gas laser.
    +Stan
    Jul 2007
    England
    CNC mounted 250mw 635nm Diode
    I have sucsessfully etched woods and plastics (the more matt the surface is the better) with a tiny little DVD-R diode.
    The diode is focused to approx 0.07mm.
    I have just cut some 3mm thick foam (medium density and dark grey in colour) at about 200mm/m. Not the fastest beast in the world. But it worked
    Could cut thicker with multiple passes.
    Have attached scan of some Tufnal about 100mm x 70mm, It had a pretty glossy surface but still etched well at about 300mm/m
  1. Foam Cutting Power Supply Questions - Non CNC
    By 11bravo in forum CNC Wire Foam Cutter Machines
    Last Post: 04-29-2007, 12:33 PM
  2. 4'X8' router needed! Simple foam project. Phoenix, AZ!
    By kburn in forum Employment Opportunity
    Last Post: 02-20-2006, 08:31 AM
  3. Foam cutter Power supply
    By wdp67 in forum CNC Wire Foam Cutter Machines
    Last Post: 01-15-2006, 01:27 AM
  4. Power needed to move big gantry?
    By DennisCNC in forum Mechanical Calculations/Engineering Design
    Last Post: 11-06-2005, 06:11 PM
  5. Power supply wiring help needed
    By DJ Morrow in forum General Electronics Discussion
    Last Post: 10-27-2005, 12:05 AM
