Results 1 to 5 of 5
Thread: which laser for wood cutting
    Jul 2007
    uk
    Question which laser for wood cutting
    im interested in which type of laser i could use to cut balsa wood say up to 3/8" ingh and maybe ply, then where do i go to buy one. any suggestions please.
    Sep 2007
    you can also check out
    www.alspi.com
    we have been building custom lasers for many years. From yag etchers to 6k CO2 systems for real cutting. (ha ha real cutting)
    May 2007
    Thailand
    Wink Laser cutter
    Hi Experter,
    If I want to cut the wood thickness about 1 inchs, How many watts for laser power properly?
    Cheers,
    Mongkol
    Sep 2007
    I personaly would hit it with about 500 watts. if you hit it with more than is needed. What you wind up doing is vaporizing the material, not flaming thruogh it. I have not been using one of these table top little models. I work at ALSPI who can be found at www.alspi.com. so I also hit it with a shield gas of nitrogen about 12-18 bars of gas. that works better for me when cutting wood. if I am cutting .5 thick metal I use conditions for that as well but use Oxygen not to shield but as an assist gas. these little things that have less than 1000 watts well that is a hobby toy to me. sorry no offend ment.
    Apr 2007
    Colombia
    I think you can cut 1" with a 100 watts lCO2 aser, at low speed.
    1. Wood questions from a metal cutting guy.
      By Stepper Monkey in forum WoodWorking
      Last Post: 03-16-2007, 08:18 PM
    2. Cutting load in wood?
      By boblon in forum DIY CNC Router Table Machines
      Last Post: 02-26-2007, 06:02 AM
    3. what's suitable Stepper motor for cutting wood?
      By SeQueNcer in forum Stepper Motors and Drives
      Last Post: 08-03-2006, 06:35 PM
    4. Cutting wood with OneCNC.
      By nagjames in forum OneCNC
      Last Post: 12-20-2005, 05:54 PM
    5. Sand/Bead Blaster wood cutting
      By DDM in forum DIY CNC Router Table Machines
      Last Post: 12-27-2004, 09:12 AM
