Results 1 to 2 of 2
Thread: Laser Pro 25W
    Sep 2006
    us
    Laser Pro 25W
    Laser Pro 25W
    Just wondering if it is possible to use this machine to cut "more or less" a stamp out of Delrin with this type of machine? I have a customer who has one and insted of me machining them he would like to cut them out with his laser, the letters are raised about .05-.075. must be pretty sharp corners. He said he has hered of it being done by another company me I can't picture it...But if so any one know of good starting condition?
    Thanks for any help!
    Jul 2007
    These lasers are made to do rubber stamps. I have not gotten into it, because it's a smelly job, and it's hard to compete with on-line rubber stamp dealers.
    I'm surprised it's not covered in your manual. Here's how I would do a Delrin
    sotary seal using 1/16" material. You need to make a male (White lettering on black) and a female (inverted and mirrored male). The male should have no outlines, but the female should have .007 to .010 outline.
    Then add a .001 outline around the seal to cut it out.
    In your case, for a simple stamp, just do the male part.
    Rubber stamps are more involved.
    Setting should be close to this:
    Engraving - speed 90% power 90% Cutting - Speed 16% Power 100% Frequency 1000
  1. Converting a laser printer into a 3d laser printer
    By Joćo Carimo in forum General Metal Working Machines
    Last Post: 04-30-2011, 04:56 PM
  2. Why buy a Laser cutter when you can modify a laser engraver.
    By spacifique1 in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 08-13-2007, 03:39 PM
  3. Laser in x3?
    By replicapro in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 12-22-2006, 01:20 PM
  4. laser art
    By 1eyedguy in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 10-17-2006, 09:00 AM
  5. example laser cut
    By owhite in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 03-22-2005, 04:24 PM
