Results 1 to 6 of 6
Thread: Laser Engraver
    Mar 2007
    Laser Engraver
    Can you take a laser engraver and make into a laser CNC machine that actually cuts through stuff?
    -Josh-
    S.N.A.F.U. miljnor's Avatar
    Jan 2005
    Most laser engravers that I've seen can cut thru thin stuff like paper, some plastics etc.
    but if your asking about metals then probably not enough wattage.
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    Mar 2007
    Can you add more wattage though.
    -Josh-
    Jan 2005
    sure you can but sometimes the cost is very prohibitive and modifications can be extensive and not worth it unless the unit is on the cheaper side..
    you would need a new laser tube and power supply (the two most expensive parts).
    thanks
    Michael T.
    Jun 2007
    united states
    Different Watt can cut through different things.
    20W Thin Plastics
    50W thin Metals
    100 W can make .010 deep marks in Metals
    I just did a test with our 10W Ostling Brand Laser and it will serrate coated plastic, but will not cut completely through.
    Jef
    Apr 2007
    China
    Our LG series engraving machine also can do cutting.
    When you want to do the cuttting, you should adjust to low speed from the software, meanwhile adjust to the bigger power.
    Jenny from Jinan G.Weike Science&Tech
    JENNY at wklaser.com
    [url]www.wklaser.com[/url]
    1. Laser Cutter/Engraver
      By jymmm in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 10-31-2010, 01:42 PM
    2. Why buy a Laser cutter when you can modify a laser engraver.
      By spacifique1 in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 08-13-2007, 03:39 PM
    3. Need Help With IE300 Laser Engraver
      By JWiggers in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 03-03-2007, 09:56 AM
    4. $500 laser engraver from China
      By tinylaser in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 11-22-2006, 10:53 PM
    5. Vytec laser engraver help
      By cmbheli in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 02-24-2005, 03:54 PM
