Page 1 of 3 123 LastLast
Results 1 to 12 of 26
Thread: Counter doesn't stop.
    Jul 2011
    Morocco
    Unhappy Counter doesn't stop.
    Hello
    Delighted to be here in this forum that I visit regularly.
    With my sincere thanks in advance, I'd like to help me solve my problem.
    The counter of my chinese laser (XYZ-TECH J6090 100 W, MPC6515, Control Panel PAD03, 4.0.0.1 HW, FW 4.1.2.3, 4.1.2.2 DLL) does not stop after the end of a job and continues counting until I turn off the machine. Meanwhile, to run the next job requires that I press PAUSE and STOP.
    I tried to update the HW and FW dozens of times but I can not.
    I reinstalled LaserCt 5.3 and applied the configuration several times but this does not fix the problem.
    A report that the beep works because I hear from other operations.
    What should I do?
    Best Regards
    Nov 2010
    Poland
    XYZ machine was the worst piece of sh...t I ever bought from China.
    CNC lasers, constructions, service
    Jul 2011
    Morocco
    Okay. But can anyone give me some ideas to understand the origin of my problem counter? Thank you
    Chinese Laser : Jinan XYZ-TECH CNC Equipment Co,.LTD, Machine : XJ6090, RECI 100 W, MPC6515, Control Panel PAD03, HW 4.0.0.1, FW 4.1.2.3, DLL 4.1.2.2. LaserCut 5.3.
    Nov 2008
    Hi there
    first you should allways delete the old files on the MPC and ones in a while format the MPC.
    befor you send a new file press the reset botton let the reset run throug.
    the probleme is with the memory what is actually on the border size for the processor the manufacturer of the processor recommend big size memory but the chinese cut corner and use the smalest what somehow works.
    greetings
    walt
    Quote Originally Posted by medmouncef View Post
    Hello
    What should I do?
    Best Regards
    Nov 2010
    Poland
    Quote Originally Posted by herby08 View Post
    Where did you find any RESET BUTTON?
    Nov 2008
    hi
    sorry I am not familiar with your machine but usually you have on the PAD a reset botton if you send a picture this would clear up something.
    greetings
    walt
    Quote Originally Posted by cinematic2 View Post
    Nov 2010
    Poland
    I have both PAD03 and PAD06.
    None of them has any RESET BUTTON.
    MPC6515 and MPC6535 systems DO NOT HAVE ANY RESET BUTTONS.
    Nov 2008
    sory like I said I dont know your machione and can not find specs for it.
    I am using a re-branded MPC 6535 and have a reset botton right next to the display maybe in your machine they using the stop botton as this then thats probably the reason that the counter still runs because the machine assumes that its still working on the same I got this if I run one item multiple times then the counter also counts further.
    gretings
    walt
    Nov 2010
    Poland
    My God!!!
    You just think about switching machine off/on !!! :-)
    This is not a solution at all.
    MPCs keep all setting and files in memory.
    Switching off/on do not solve such problems.
    I though you may know any "secret button" resetting MPC to factory settings :-(
    But you don`t.
    Nov 2008
    He hey my friend
    I try to help you out but if you think that somebody will help you if you go so agressiv then dont expect this.
    like I said without picture of your machine and what is on nobody can realy give advice because it looks like you have the worth machine with lots of short cuts.
    I have revised and rebuild quite a few machines with all kinds of controller and I know from them what normaly happen.
    according to the manufacutrer manual you need to press the stop botton befor you load a new file then the counter will also stop.
    you can delete all files on the MPCs with the menue function.
    greetings
    walt
    My God!!!
    But you don`t.
    Nov 2010
    Poland
    Did I said I need any help?
    No, I don`t.
    I just fought for a moment you know hidden MPC function.
    But you don`t.
    Dear Friend, we do not need here advices like "switch machine OFF an ON, should work better"
    Nov 2008
    hi
    you are one of a kind I just hope nobody else falls for you
    you are even talk for the others here I dont believe it !
    I did not say anywhere to switch the machine off and on this was you who wrote this.
    now its not worth to comunicate further
    greetings
    walt
    No, I don`t.
    But you don`t.
  • Page 1 of 3 123 LastLast
    1. Need Help!- Limit switches,can i program them to just stop, and not punch out the E-stop in mach
      By Vegabond in forum Mach Wizards, Macros, & Addons
      Last Post: 12-30-2011, 08:29 PM
    2. Replies: 0
      Last Post: 11-17-2011, 01:30 PM
    3. Replies: 0
      Last Post: 11-12-2011, 01:10 AM
    4. New Machine Build- Generic Emergency Stop (E-Stop) Design Concepts?
      By zipzit in forum General Electronics Discussion
      Last Post: 06-09-2011, 07:14 AM
    5. New Machine Build- EMC2 E-stop parallel port pinout and E-stop loop
      By GreenLead in forum LinuxCNC (formerly EMC2)
      Last Post: 08-03-2010, 01:05 PM
