Results 1 to 7 of 7
Thread: 25.4mm lens for cutting?
    Mar 2012
    ireland
    im working with 1.5mm plywood and using a 50.8mm lens for cutting.
    just wondering if anyone has experience cutting with a F.L
    of 25.4mm and if it would be a better suited lens for cutting 1.5mm plywood,
    the 50.8mm lens is leaving burn marks,i dont have the option of being able to use an air compressor and thinking the 25.4mm lens has a smaller spot so less chance of a flame appearing but i dont know if its depth of field is
    suitable for cutting 1.5mm plywood,
    thanks,
    Apr 2007
    UK
    same power focussed onto a smaller spot = higher power density = more chance of fire
    Without air assist you won't be able to get much improvement on the staining / scorching. You also run the risk of damaging the lens if you use a short focal length. a 1" (25mm) lens isn't really designed for use on anything other than surface marking at high resolution.
    best wishes
    Dave
    Mar 2012
    ireland
    thanks Dave,
    Registered GWEIKE-LASER's Avatar
    Apr 2008
    CHINA
    Jenny@wklaser.com
    even the shot focus lens can not solve the problem of burn edge.
    do not suggest use shot focus lens for cutting.
    jenny@wklaser.com
    skype:ms.leizhang www.wklaser.com
    Mar 2012
    ireland
    thanks GWEIKE-LASER,
    i found this great calculator for laser optics;
    Laser Optics Calculators
    Apr 2008
    CHINA
    JENNY@wklaser.com
    namara, good sharing
    jenny@wklaser.com
    Registered Rodney Gold's Avatar
    Mar 2007
    South Africa
    What you can try to minimise charring is 3 fold in your case
    1) go to a 40mm lens for higher power density but more or less the same depth of focus
    2) Mask the top and bottom surfaces with cheap self low tack adhesive paper (get it from a vinyl sign supplier , called application tape)
    3) More importantly , depending on what laser you are using , adjust your pulses per inch downward or use dot mode on some chinese machines
    Basically you want to "just perforate" the cut line but with enough overlap between perforations to give a smooth edge but not too much to heat damage the edges.
    You will never get a clean edge but can minimise charring
    1. Need Help!- Lens contamination cutting with shop air.
      By LaserPro in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 08-18-2012, 05:07 AM
    2. new lens
      By curious in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 10-25-2011, 11:31 AM
    3. Collimator Lens
      By bdring in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 10-04-2009, 10:17 PM
    4. DUAL FOCUS LENS (bifocal lens)
      By bibi in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 03-17-2009, 06:03 PM
    5. Where to buy lens?
      By medved in forum Mechanical Calculations/Engineering Design
      Last Post: 12-30-2005, 03:49 AM
