Results 1 to 11 of 11
Thread: Laser cutter wont cut/engrave
    Apr 2012
    Macedonia
    Hi
    I'm new to this laser cut systems. But from the start there is a problem even though the company that I bought machine from says that everything should work good. I had to say reading the posts on these forum these past few days I learned more than ever . But still I have a problem cutting /engraving.
    I have a 80 wCO2 laser tube work table 900 x600 mm MPC6515 motion card and LaserCut 5.3 software. First I had a problem instaling drivers for MPC6515 and now I can not cut through mdf or acrylic not even engraving like I thought it should. I also tryed to engrave on hard wood or do the grade engrave but the result is almost the same every time --I get marking or 1mm deepest engraving or almost 2mm deep cut.
    Can someone please help me trough this. What should I do ???
    I lost a week trying and no good response from the company (they are from Australya but the machine is Chinese)
    Thank You
    Goran
    Apr 2010
    Check and then double check your mirror alignment
    Apr 2012
    Macedonia
    Thank You for the answer so if you can just tell me how should I do that ? Like I said I'm new at this and I have not much support from the company that sold me that laser. And is new but...
    Nov 2010
    Poland
    This is why laser machine should have REAL Red Point with red dot going through whole optics.
    CNC lasers, constructions, service
    Apr 2012
    Macedonia
    Ok
    Thanks for that opinion but I already lost a lot of time setting this machine and I also want to see her working. So can please someone tell me what to do to start with working and production if it's possible.
    Thank You
    Goran
    Nov 2010
    Poland
    First check your mirrors and lens to be clear.
    Than take some self adhesive paper tape and put on the window before last mirror.
    Check if the laser makes signs in the middle.
    In all positions (upper left, upper right, lower left and lower right) must be well centred.
    Set short pulse and 50% power in LaserCut or what you have.
    Do it as shortly as you can.
    Do not fire the tape or you will make your 3 mirror dirty.
    Also check 3 mirror setting.
    Take a piece of tape and set down on laser output hole below lens.
    Press the tape with a finger to impress trace where the hole is.
    Than make another laser shot and check the tape if the sign is in the EXACT CENTER. Must be. And should be round.
    That is all.
    Apr 2012
    Macedonia
    Thank You a lot. I will try these steps and I'll wright back tomorrow because it's already late now here.But I hope that this will finally set up laser to work.
    Thank You
    Apr 2012
    Macedonia
    Problem Cut/engrave -bit better
    Well I just try moving the tube a bit and I got a new result -- the laser made a cut 5mm deep in acrylic but on the upper left side. Moving it on the right I can get only 2mm deep cut. So Is there a chance that only a tube possition is the problem or should I set the mirrors as well.
    Goran
    Nov 2010
    Poland
    mirrors
    Apr 2012
    Macedonia
    Smile
    Well thank You Cinematic2. I'm going...
    Feb 2005
    Goran, here is a good youtube video that shows the complete setup procedure and mirror alignment. Hope this helps.
    http://www.youtube.com/watch?v=bwrdH49ARWc]CO2 Laser Machine Setup - YouTube
    1. Material to cut / engrave in my new laser
      By herrmc in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 04-15-2012, 11:57 AM
    2. Need Help!- I need a laser engrave
      By flinstone in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 04-21-2011, 01:57 AM
    3. Need Help!- Laser table wont lift up (GCC/ Laser Pro Mercury II)
      By aussiemate in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 03-03-2011, 08:47 AM
    4. How to engrave pcb with laser
      By codes in forum General Metal Working Machines
      Last Post: 03-17-2008, 04:23 PM
    5. Need laser to engrave photos
      By aerialpixs in forum Engraving Machines
      Last Post: 12-17-2007, 11:34 PM
