Results 1 to 7 of 7
Thread: Focal Lens
    Apr 2010
    Focal Lens
    Has anyone hear done some shopping for a different lens other than what their machine came with ?
    My machine has a 55mm lens on the 60 watt and it cuts 9mm acrylic pretty good but the engrave is excellent, the engrave must be .010. My 150 watt has a 68mm lens and it cuts the acrylic alot better, the engrave is ok (as expected)
    While testing the engraving with the 60 watt it was tough to keep a white film from appearing on the acrylic surface, turning down the power to about 20 percent fixed that but I would like the engrave to go a little deeper, is there a trick that I dont know about ?
    Does anyone have a recomendation for a len's ? any why.
    Feb 2012
    China
    Quote Originally Posted by bundysax View Post
    bundysax
    yes,we made like this ,if machine is 50mm focus,customer need spare one ,we will suggest 63.5mm or 100mm for thick materials,but the focus distance maybe a little diffrent,so when you change to other focus,need to test the distance again,
    Any others,feel free to ask us
    Best Wishes
    Lucy Lee
    G.WEIKE LASER
    han@wklaser.com
    Company Representative Melody-gweike's Avatar
    Sep 2011
    China
    Dear bundysax,
    If you want to engrave deeper, you should choose larger power and slow speed setting when engraving. And can't the white film removed? Sometimes, it can easily removed by a piece of cloth. Because we have sold many machines, i think the lens we use for engraving and cutting should be suitable.
    Melody
    melody@vip.163.com li@wklaser.com
    skype:melody.gweike
    Apr 2007
    UK
    Power Density
    Depth Of Field
    best wishes
    Dave
    Apr 2010
    Thanks Dave very interesting, the power density was very interesting on how the power multiplies so much with such a little adjustment in the beam.
    What I dont understand is the focal length, I understand the principal to focus the beam to the smallest spot as possible but I dont understand the different focal lengths. From what I have read some of the most powerful lenses focal length is 100mm, why not 50mm or even 68 mm ? If you can get a nice tight beam at 50mm why would it be more powerful at 100mm ?
    Apr 2007
    UK
    Hiyaz,
    The longer focal length lens have a longer depth of field, ie: the length the beam is focussed at is longer (deeper) so making cutting thicker materials easier (they give a straighter cut) the spot size however is also bigger and as you will have read above, bigger spot = lower power density
    best wishes
    Dave
    Apr 2010
    Gotcha,
    1. Focal length
      By mondo50m in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 01-10-2012, 01:34 PM
    2. new lens
      By curious in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 10-25-2011, 11:31 AM
    3. Need Help!- focal lens
      By adrianhdezch in forum Engraving Machines
      Last Post: 10-18-2010, 01:58 AM
    4. DUAL FOCUS LENS (bifocal lens)
      By bibi in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 03-17-2009, 06:03 PM
    5. Where to buy lens?
      By medved in forum Mechanical Calculations/Engineering Design
      Last Post: 12-30-2005, 03:49 AM
