Commerical DSP CO2 Laser Engraving/ Cutter Control system comes with a LCD control panel ,control card and related software. The system supports CorelDraw (v12 or higher version) and AutoCad (2004 or higher version) in the way of 'What you see is what you'll get'. And it Can achieve the fuction of setted completely offline (pc) , U disk file read and write, USB high-speed communication.,Dual-laser power setted separately, break-point memory,etc.The system Can achieve 360-degree slope carving effect, to support high-speed data transmit by network,is the ideal control system to industry of clothing, leather cutting, organic glass cutting, rubber print plate carving,etc.
These controllers were not only available to machine manufacturers,but also suitable for home retrofit of a small machine or DIY.If you want to know more about our products,pls fell free to contact with Robert through MSN: robertzhou1982@hotmail.com or Skype:robertzhou1982.
