Hi Steve ,
I've not worked with lasers,
but I'd not run the supply without a load to avoid damage to the insulation
a 5W to 10W load could be a good start
if the voltage across a working tube is about 20000 to 25000 volts
you may be able to use a number of high voltage resistors as a dummy load
and use an EHT meter , as used to test the EHT supply to CRT
the EHT probe I have contains a single 8" long 990M ohm resistor
combined with the 10M ohm input resistance of my multimeter , divides the voltage being measured by 100
it so happens in the April edition of EPE magazine one project is for an EHT
probe
EPEMag Online
John
LinkBack URL
About LinkBacks
