Results 1 to 10 of 10
Thread: QX Series Hot-sale Laser Engraving/Cutting Machine
    Registered lucylucky's Avatar
    Sep 2011
    China
    Hi everyone,
    This is Lucy from Jinan Quanxing Mechanical Equipment Co., Ltd which is specialized in Laser Machine and CNC Router with CE and FDA.
    QX Series Hot sale Laser Machine:
    Desktop QX5030
    Small QX4060, QX6090
    Economical QX1290, QX1490, QX1690
    Large QX1218, QX1325, QX1620, QX1630.
    Technical Details:
    1. Model: QX1290
    2. Working area: 1200X900mm
    3. Laser Power: 80W
    4. Optional Power: 60W, 100W, 120W, 130W, 150W
    5. Laser Types: Hermetic And Detached CO2 Laser Tube
    6. Engraving speed: 0-75,000mm/min
    7. Cutting speed: 0-40,000mm/min
    8. Location precision: ≤0.01mm
    9. Resetting positioning accuracy: ≤0.01mm
    10. Power supply: AC 220V/50Hz
    11. Gross power: <1,000W
    12. Operating temperature: 0 - 45°
    13. Operating humidity: 5 - 95%
    14. Minimum shaping character: English 1×1mm
    15. 360°slope engrave: Yes
    16. Driving system: stepper
    17. Cooling mode: Water-cooling and protection system
    18. Auxiliary Devices: Exhauster And Exhaust Pipe
    19. Software: Lasercut 5.3
    20. Graphic format supported: BMP, CIF, JPEG, TGA, TIFF, PLT, AI, DXF, DST (TIANDAO Embroidery Software), DWG, CDR, etc
    21. Optional: Up& Down work table, Digital display, Rotary Clamp, Red light pointer, Auto focus,
    22. Optional water cooling system: water pump, water chiller, air cooler
    23. Applications: Acrylic, PVC, rubber sheet, plastic, crystal, glass, wood, bamboo, marble, leather, cloth, double-color board, etc. Nonmetal materials
    If they are of your interest, your inquiry is always welcome.
    Thanks and Regards
    Lucy
    Jinan Quanxing Mechanical Equipment Co.,Ltd
    Email: huanjiaoxiao@hotmail.com
    Mob: 008618254116182
    Skype: huanjiaoxiao
    Ms Lucy (Laser Engraving and Cutting Machine Manufacture)
    Mobile: 008618254116182 MSN: huanjiaoxiao@hotmail.com www.quanxinglaser.com
    Sep 2011
    China
    QX Sereis Econormical CO2 Laser Engraver/Cutter
    Hi everyone,
    Glad to share with you our Economical Laser Engraver/Cutter Details:
    Model: QX1290, QX1490, QX1690
    Standard Parts:1. Leetro card with USB
    2. 3-phase motor
    3. 80W CO2 Laser Tube
    4. Slat worktable with funnel
    5. Water flow sensor
    6. Water pump
    7. Air pump
    8. Exhaust fan
    Optional Parts:
    1. Dual Red Pointer
    2. up&down table
    3. Rotary clamp
    4. Water chiller
    5. Auto focus
    Technical Parameter:
    • 1. Model: QX1290
    • 2. Working area: 1200X900mm
    • 3. Laser Power: 80W
    • 4. Optional Power: 60W, 100W, 120W, 130W, 150W
    • 5. Laser Types: Hermetic And Detached CO2 Laser Tube
    • 6. Engraving speed: 0-75,000mm/min
    • 7. Cutting speed: 0-40,000mm/min
    • 8. Location precision: ≤0.01mm
    • 9. Resetting positioning accuracy: ≤0.01mm
    • 10. Power supply: AC 220V/50Hz
    • 11. Gross power: <1,000W
    • 12. Operating temperature: 0 - 45°
    • 13. Operating humidity: 5 - 95%
    • 14. Minimum shaping character: English 1×1mm
    • 15. 360°slope engrave: Yes
    • 16. Driving system: stepper
    • 17. Cooling mode: Water-cooling and protection system
    • 18. Auxiliary Devices: Exhauster And Exhaust Pipe
    • 19. Software: Lasercut 5.3
    • 20. Graphic format supported: BMP, CIF, JPEG, TGA, TIFF, PLT, AI, DXF, DST (TIANDAO Embroidery Software), DWG, CDR, etc
    • 21. Optional: Up& Down work table, Digital display, Rotary Clamp, Red light pointer, Auto focus,
    • 22. Optional water cooling system: water pump, water chiller, air cooler
    • 23. Applications: Acrylic, PVC, rubber sheet, plastic, crystal, glass, wood, bamboo, marble, leather, cloth, double-color board, etc. Nonmetal materials
    Trading Terms
    • Delivery time: 7-10 working days after your order.
    • Warranty: 1 year for every part of machine, except for laser tube for 3 months, because laser tube is spendable.
    • After-sales service: 24 hours technical support, Video and Manual to guide you how to install, operate, maintain machine step by step.
    • Payment terms: 50% T/T in advance, the balance should be paid after machine ready.
    E. How to select suitable machine?
    • What Materials you need engrave or cut, Nonmetal, Metal or Both? ( Choose Laser, CNC, or Plasma)
    • What's Max. working area of materials you need process? (Choose Model of machine)
    • What's Max. depth you'll need engrave or cut? Mainly engrave or cut? (Choose laser power)
    Sep 2011
    China
    QX Series Economical Laser Machine Reference Photos
    Attached Thumbnails Attached Thumbnails QX Series Hot-sale Laser Engraving/Cutting Machine-52.jpg   QX Series Hot-sale Laser Engraving/Cutting Machine-53.jpg   QX Series Hot-sale Laser Engraving/Cutting Machine-1290d.jpg   QX Series Hot-sale Laser Engraving/Cutting Machine-driver.jpg
    QX Series Hot-sale Laser Engraving/Cutting Machine-g-2-head.jpg   QX Series Hot-sale Laser Engraving/Cutting Machine-4.jpg
    Sep 2011
    China
    QX Series Laser Machine Feature
    QX Series Laser Machine Feature:
    1. Waste collect device.
    2. Both Flat engraving table and slat cutting worktable
    3. DSP Offline Control System with USB interface.
    4. Dual red dot pointer.
    5. Separate control system box, separate laser power box, separate control panel
    6. Better wiring and assembling
    7. External spares plug and socket
    8. Protective switch and labels. This is VERY IMPORTANT for your direct users to operate the machine SAFELY.
    9. High quality nuts, screws, rails, motor and spares
    10. Stronger steel material thickness of machine body
    11. Professional and timely after sales service. This is VERY IMPORTANT for whether an end user or a distributor.
    Hope they could help you choose suitable machine.
    Any question, please feel free to email me.
    Ms Lucy
    Attached Thumbnails Attached Thumbnails QX Series Hot-sale Laser Engraving/Cutting Machine-5.jpg   QX Series Hot-sale Laser Engraving/Cutting Machine-driver.jpg   QX Series Hot-sale Laser Engraving/Cutting Machine-4.jpg   QX Series Hot-sale Laser Engraving/Cutting Machine-img_2070.jpg
    QX Series Hot-sale Laser Engraving/Cutting Machine-img_2061.jpg
    Sep 2011
    China
    Dual Heads Laser Machine
    Hi everyone,
    Glad to share with you our QX Series Laser Machine.
    Now, Dual Heads Laser Machine: QX1290D, QX1490D, QX1690D, QX1325D
    1) Two laser tubes and two laser heads working simultaneously, which makes processing efficiency doubled.
    2) Cost saving and cutting well-proportioned.
    3) Used when offline and laser intensity can be controlled separately.
    Miss Lucy
    T: 86 0531 82561779 | F: 86 0531 82730577 | M: 8618254116182
    E:lucy@jnquanxing.cn​ W: ¼ÃÄÏȪÐÇ»úеÉ豸ÓÐÏÞ¹«Ë¾
    MSN:huanjiaoxiao@hotmail.com​ Skype: huanjiaoxiao
    Attached Thumbnails Attached Thumbnails QX Series Hot-sale Laser Engraving/Cutting Machine-sam_1356.jpg
    Sep 2011
    China
    Double Heads Laser Machine Photos
    Sep 2011
    China
    Feature of Dual Heads Laser Machine
    Advantage Features:
    1.Two laser tubes working together or alternatively
    2.Save programming time and tube cost
    3.Equiped with a low power, high precision engraving laser tube and a high power cutting laser tube, the operation of engraving and cutting can be completed in one machine
    4.Unique design: the space between two heads can be freely adjusted
    5.Strong structure enables the machine moving steady and speedy with high precision, maintaining high carving precision long time unchanged. run-through boby design suitable for infinite length work piece processing
    Sep 2011
    China
    Please check dual heads machine photos. If they are of your interests. Please feel free to call me Mob:0086-18254116182 or email me, lucy@jnquanxing.com
    Attached Thumbnails Attached Thumbnails QX Series Hot-sale Laser Engraving/Cutting Machine-sam_1352_1_.jpg   QX Series Hot-sale Laser Engraving/Cutting Machine-sam_1423.jpg   QX Series Hot-sale Laser Engraving/Cutting Machine-sam_1432.jpg   QX Series Hot-sale Laser Engraving/Cutting Machine-sam_1437.jpg
    Sep 2011
    China
    Feature of Quanxing Laser Machine
    1. This machine adopts the DSP data control technique, and incorporate design profile structure, which creates the durative, fast curve cutting function and optimize the shortest processing path function in the same field, so improves the working efficiency greatly.
    2. It adopts the International standard linear guide rail, which makes machine running more smoothly and accurately.
    3. High Security.1) Detailed warning and instruction lable complied with CE; 2) Most advanced Dual limit switch protection on XYZ axis, preventing the bump of laser head. 3) High quality water flow sensor to inspect water circulation in laser tube, which can protect the laser*tube.
    4. It adopts the most advanced focus method: Dual red light pointer, which makes laser focus much easy, accurate and more personalized, no need any focusing tools.
    5. It adopts up and down style by the step motor, which makes the motorized up and down working table steadier, smaller noise and faster speed and so on.
    6. Front & Rear entry for super-long plate to pass through.
    Waste collect device, easy to pick up samples and save raw materials.
    Separate control system box, separate laser power box, separate control panel, External spares plug and socket much sate for machine.
    High quality nuts, screws, rails, motor and spares. Better wiring and assembling. Stronger steel material thickness of machine body.
    7. Laser Machine software: 1) Lasercut5.3 with dongle and LCD Key Board ( Leetro Card) 2) Laser work software without dongle and LCD Key Board (RD CAM)
    8. Synchronous Belt transmission technology and semi-closed-loop structure, engraving with high precision and fast speed (engraving speed up to 800-1000mm/s)
    9. Motor: for standard, we use Stepper Motor making machine working fast and stable. We could also use optional Servo Motor according clients requirement. Servo Motor is much fast than stepper motor also with high precision.
    Sep 2011
    China
    Smile
    1. New Machine Build- Hot sale mini laser engraving machine
      By Paulette in forum Commercial CNC Wood Routers
      Last Post: 02-21-2012, 10:13 PM
    2. sell laser engraving and cutting machine, laser marking machine
      By lindagstar in forum Trade Shows and Events
      Last Post: 08-27-2011, 06:39 AM
    3. Need Help!- CMA-6040 Laser Cutting & Engraving Machine by Han's Yueming Laser
      By vksingh in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 07-01-2011, 11:52 PM
    4. New Machine Build- quality and cheap laser engraving machine for sale
      By Jenniferxu in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 12-29-2010, 07:20 PM
    5. JD Series Laser Engraving Cutting Machine
      By echojdlaser in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 12-03-2010, 09:40 AM
