Results 1 to 4 of 4
Thread: 40W CO2 Deluxe Hobby Laser - to cut WOOD
    Mar 2012
    Greetings,
    I am looking into purchasing the 40W CO2 Deluxe Hobby Laser.
    My primary use of the machine would be to cut 1/4" thick patterns in various species of wood. Can all, or most wood species be cut?
    Will there be burn marks?
    Do I need to buy the 2.5" focus lens for this application?
    Apr 2007
    UK
    Yes they can be cut but not all at an acceptable standard. Hardwoods and those that contain more *oil* will make more of a mess usually.
    Very much so, the edge of the wood will be black or charred unless you use an inert gas assist system such as Nitrogen.
    Longer focal lengths increase the depth of field (an explanation HERE) but going from 50 to 63.5mm won't make a great deal of difference.
    To cut 1/4" wood a 40 watt machine is going to struggle to reach anywhere near a decent linear speed. 80 watts would be better and 120 watts would be my choice if I was looking at doing the same.
    Given your requirements (or my assumption of them) a router would be a better tool for the job.
    best wishes
    Dave
    Jun 2011
    The FSE 40watt will torch the hell out of your wood. Its nowhere near powerful enough to cut that at any speed that wont burn the wood quite badly.
    Apr 2006
    I agree with Exsecratio on most all of his response.
    You should look at a laser machine with closer to 80 watts. A 60 watt laser would do the work if you can stick to birch, pine, or other soft wood. A plywood might be great for some projects.. It might make more sense to be particular about your target materials.
    We sell a laser machine RL-60-9060. The work space is 36 wide x 24 front-back. This laser machine can also be purchased as an 80 watt laser power.
    It really depends on what your projects are .. maybe a CNC router would do better.. Many projects would NEED a laser to get the particular work done.
    Ray Scott
    Owner / Engineer
    Rabbit Laser USA
    513-217-5707
  1. Replies: 0
    Last Post: 08-14-2011, 10:08 PM
  2. 40W Deluxe Hobby Laser for $2,350
    By fslaserboy in forum Engraving Machines
    Last Post: 07-07-2011, 09:59 PM
  3. which laser for wood cutting
    By colormecnc in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 09-14-2007, 02:05 PM
  4. my hobby laser cutter - tombstones
    By KTP in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 02-09-2006, 08:51 PM
