IMO you don't need to worry about the 50Hz / 60Hz as there will be no component parts that are that frequency dependant. The easiest solution would be to buy a 110 to 210 volt step-up transformer (that is rated to handle the total machine current requirements) and use that in the line.
Are you sure you don't have two phase incoming supply that will provide 220 Volts ??
Tweakie.
LinkBack URL
About LinkBacks
