Results 1 to 2 of 2
Thread: Help - Raised edges on face of acrylic
    Oct 2009
    Hello all,
    I was wondering if anyone out there had a solution to the raised top edges I am getting on acrylic. I can minimize the visibility of the raised edges but only at the expense of the smoothness of the actual edge. Using faster speed and multiple passes gives lousy edge results. Can this be fixed with stronger air assist?
    I am using the Full Spectrum 40W Deluxe with and without the honeycomb table. It was cut out of 3mm Cast Acrylic. I have tried with the stock paper both on and off and also tried replacing it with a medium tack paper mask. None of that seemed to make much of a diffence.
    http://imageshack.us/photo/my-images/823/img5209f.jpg/
    Apr 2007
    UK
    Could be material quality?
    Some *acrylic* is cheap imported stuff that gives an aweful finish, try a small piece of genuine "Perspex" with known providence to see if you get the same results?
    best wishes
    Dave
  1. What causes "rough" edges when laser cutting acrylic?
    By shobley in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 04-28-2011, 07:19 AM
  2. Laser Cutting 3/8" White Acrylic & Getting Burned Edges
    By RJlaser in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 04-06-2010, 11:52 AM
  3. Raised Text
    By roland88 in forum General CAM Discussion
    Last Post: 11-19-2007, 04:35 AM
  4. Raised Letters
    By Astroguy in forum Mach Mill
    Last Post: 09-11-2007, 08:42 PM
  5. angular contact bearings face to face??
    By powerfade in forum DIY CNC Router Table Machines
    Last Post: 06-19-2005, 12:01 AM
