Results 1 to 6 of 6
Thread: Different result with the same materials
    Oct 2011
    Ukraine
    Hi.
    I was analysing different examples of laser working on Acryl (PMMA) and found one interesting thing.
    At the first picture we can see vaporized material and melted edges.
    At the second example we can see situation like material was boiled and then frozen.
    All that work was made on CO2 laser engraver/cutter.
    How can I reach the second result? What parematers should vary to accomplish that? Power, speed, focus distance? May be cooling of cut point?
    Any ideas?
    Attached Thumbnails Attached Thumbnails Different result with the same materials-cut1.jpg   Different result with the same materials-cut2.jpg
    Registered Tweakie's Avatar
    Nov 2009
    UK
    What is the material and what is the scale of your photos ??
    Tweakie.
    CNC is only limited by our imagination.
    Oct 2011
    Ukraine
    Material is PMMA (Akryl). The width of cut at pict.1 is about 0.1 mm. The next picture present edge of cut 0.2 mm wide.
    Nov 2009
    UK
    So, if I am understanding this correctly, the first picture shows a smooth edge as would be achieved by cutting at the correct speed.
    The second picture shows the edge which has been cut too fast and possibly with too much air assist. The material has cooled before it has had time to flow into a smooth edge.
    Tweakie.
    Oct 2011
    Ukraine
    Well, it might be true.
    Can it be if the laser beam was bit disfocused?
    Nov 2009
    UK
    Possible, but acrylic tends to act as a waveguide at 10.6um so focus does not have quite the same effect as it does with other materials.
    As an example, 10mm acrylic can be cut with straight sides yet there is divergence to the beam shape which, in theory, should produce a 'wine glass' shape.
    Just a thought.
    Tweakie.
    1. MDF cutting result... good? pic
      By Propaganda in forum WoodWorking
      Last Post: 05-16-2010, 03:42 PM
    2. Newbie- mach3 drivertest result
      By chepot in forum Mach Mill
      Last Post: 04-11-2009, 10:25 AM
    3. Need Help!- kcam HPGL DXF result
      By Isaak in forum Kellyware CAM
      Last Post: 04-27-2008, 01:29 PM
    4. changing result of alarm
      By spock in forum Sharp CNC
      Last Post: 01-26-2008, 10:35 AM
    5. End result
      By Ken_Shea in forum OneCNC
      Last Post: 05-13-2003, 10:06 PM
