Results 1 to 5 of 5
Thread: Laser tube emitting continuous beam
    May 2007
    Hi, All.
    I have a question I thought I might ask about my Synrad 48-2 CO2 tube.
    My Problem:
    My laser tube has just started emitting a continuous beam, whenever it is on. It started doing this right in the middle of an engrave file last night, and does this whether or not the signal cable from the engraver is plugged in to the tube. I have taken a look at everything, using a multi-meter to see if the signal is being emitted from the engraver, and I am reading almost 5-volts at either end of my signal cable, every time I press the "test" button.
    Possible Reason:
    - I relocated my machine (which is on wheels) a few feet, minutes before this began happening last night. I wonder if I may have run over the cord and created a short in the line (there are many cords), or even broke the signal-jack.
    Another Possible, Mysterious Reason:
    - This behavior is coincidental and unrelated to me moving my machine, even though I have never yet experienced this behavior with my laser tube. Has anyone ever had experience with this happening with a Synrad tube before? The only time that my tube shoots out a continuous beam is when it is not hooked up to any signal wire and I plug it straight into the wall.
    Any advice would be appreciated. Thanks.
    Jon
    Oct 2010
    I think it's time to break out the multimeter and look for a short, or break in the wires.
    May 2007
    Still working on that. I am hoping that it is only the jack. The wires seem ok, so far...
    Registered Rodney Gold's Avatar
    Mar 2007
    South Africa
    Mail synrad , they reply real quick , they will tell you where to look.
    Jun 2011
    Czech Republic
    try to use a oscilloscope to see the shape of the low 5v puls
    or check if the high voltage cable isnt near other cable(interference)
    this happend to me.
    1. Need Help!- Laser Beam alignment
      By graver1 in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 01-23-2011, 11:48 PM
    2. No laser beam?
      By moos in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 09-23-2009, 01:48 AM
    3. Need Help!- How align IR beam (co2) with visible beam (red dot laser) ?
      By etienne delcuve in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 02-04-2009, 06:41 AM
    4. Column of laser beam...
      By pedroman in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 07-25-2007, 01:34 AM
    5. what is laser beam combiner ?
      By max_imum2000 in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 02-24-2007, 12:31 PM
