Results 1 to 6 of 6
Thread: cutting Carbon Fiber and Engraving Rubber
    Feb 2004
    Dallas Texas
    I'm Looking for information on a laser to both engrave rubber stem bumpers, and also cut through 1/32" and 1/16" carbon fiber sheet.
    Is this possible with a small inexpensive desktop laser, or is the cutting going to require more power?
    Obviously, the small cheap ones on ebay that go for $800 are attractive, but I don't know much about them. If I can do this economically, I can get there, but if it's going to cost too much, I'll have to keep cutting the carbon fiber with a router.
    Thanks in advance for any help!
    Royce Bunnell
    OB Cue Shafts and OB Cues
    Registered Tweakie's Avatar
    Nov 2009
    UK
    Hi Royce,
    The $800 models will not cut carbon fibre sheet.
    Some rubber compounds engrave OK others just get messy so you would have to do a trial piece to be certain.
    Tweakie.
    CNC is only limited by our imagination.
    Feb 2004
    Dallas Texas
    Tweakie,
    Thanks for the info
    I think they are 40 watt, so what machines would cut the carbon fiber, and what kind of power am I looking at?
    Royce Bunnell
    Nov 2009
    UK
    Hi Royce,
    This was extracted from a Synrad data sheet.
    Cutting Carbon Fiber
    Process Date: April 2002
    Clean cuts were achieved on the 0.02"-thick woven carbon fiber in the photo above, using a Synrad Evo200W laser with 5psi air assist. The cuts were made at a speed of 290 inches per minute in the direction of the weave. The diagonal cut was made at a slightly slower speed, 210 inches per minute, due to the variation of the material density.
    Tweakie.
    Feb 2004
    Dallas Texas
    will it cut 1/16" Carbon Fiber?
    Morn,
    Thanks for your reply. I've looked at your website, briefly, and noticed that your address is listed in the US. Are you in the US, and would you or someone competent be available at that location for a few questions if I need help? I'm pretty well versed in CNC and automation, but lasers would be new to me.
    Also, will it cut the carbon fiber sheets. Mostly, I would be cutting 1/32, but would also need to cut 1/16 as well. Basically, I make little round discs about .562" in diameter. I cut them from a 3x12 or 6x12 sheet. Currently I use a router based cnc to cut them.
    The rubber I would cut is for a black rubber stem bumper. We make pool cues and would use this to engrave our logo in the face of the bumper. I believe the rubber is a shoreA 60 in styrene butadiene. I see many others that are done this way with the same material, so I assume it should be easy to do. I know one person who uses a 50 watt Co2 laser and has good results. It's an epilog machine and is much larger than what I'm looking for.
    I am interested in your machine given it can do what I need, and it doesn't cost too much. I would also need to know that I could get some assistance if needed.
    Royce Bunnell
    Feb 2004
    Dallas Texas
    Morn
    I emailed you my contact info, so please have your US representatives contact me.
    Royce
    1. Cutting Carbon Fiber
      By TazChris in forum Composites, Exotic Metals etc
      Last Post: 12-20-2012, 08:44 AM
    2. Cutting Carbon Fiber
      By jascamera in forum CNC Machining Centers
      Last Post: 11-28-2011, 07:31 PM
    3. Need Help!- Cutting molded carbon fiber
      By alec in forum Composites, Exotic Metals etc
      Last Post: 02-08-2008, 07:40 PM
    4. Has anyone tried cutting Carbon Fiber?
      By A+ Machining in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 09-27-2007, 02:17 PM
    5. Carbon fiber cnc cutting
      By BFcarbon in forum Parts for Radio Control Models
      Last Post: 03-01-2006, 09:31 PM
